小房子的热桥和凝结噩梦
Help!
我最近完成了我的小房子建造的I thought I took comprehensive measures to build a robust system to avoid moisture issues but after living in the house for a few months I am having a huge and unexpected issue.
我们一直在整个房屋中都在特定且一致的景点中凝结水。特别是在地板上的外围,位于外墙6英寸以内且没有充足的露天流量。区域包括橱柜下方,壁橱的背面,沙发下方等。当墙壁旁边的地板上留在地板上,即一个盒子,背包时,它甚至发生在敞开中。每天在这些地方的水分都在凝结,我们无法跟上试图擦拭难度到达的区域的步伐,霉菌开始增长。我对霉菌非常敏感,老实说,我们有点噩梦,帮助!
这座房子长24',建在铁鹰拖车上。我们在西北太平洋(气候4 C)。我高度怀疑我们在这些区域有主要的冷点,因为拖车设计周围有10英寸的法兰(请参阅图片),在这些区域不允许任何绝缘层。您会看到地板确实落入框架中,该框架被岩羊毛隔热,但周围不是周围。在构建过程中,我们观看了其他人的所作所为,似乎在金属和墙壁系统/子地板之间放置窗台密封将充分减轻热桥梁。当然,这还不够。
I don’t think there is excessive moisture in the space, none of the windows are condensing except the door. Floors are vinyl plank which seem to stay pretty cold even when the house is hot. Heating is a wood stove.
I am looking for ideas and possible solutions. Hopefully something that doesn’t involve ripping apart the house. So far I am testing an experiment with gluing 2″ rigid foam under the trailer to the metal flanges and adjacent area to help mitigate the thermal bridging. So far it is unsuccessful or not at least not helping enough. We have thought about spray foaming the entire underside of the trailer but especially the perimeter flange cavity. This isn’t totally ideal though because we have bolts fastening the wall system to the trailer that would get covered. We are also considering skirting the house and insulating with rigid foam. Thoughts? Ideas? Thanks!
GBA细节库
由气候和房屋部分组织的一千个建筑细节的集合
您是否将内部湿度降低至30%?
>地板确实掉进了被岩羊毛绝缘的框架
Never use fiber insulation with an exterior side vapor barrier (like steel plate).
That is a pretty ugly detail and a big thermal bridge.
最好的方法是向后拉橱柜,并用一层刚性泡沫和重新安装来包裹金属部分。您想将泡沫带到足以完全覆盖金属部分。确保您的空气密封良好,因为任何空气都会在泡沫后面再次引起冷凝问题。
另一个选择是用较小的2个泡沫套件之一喷洒区域。这将做得更好,可以使其密封,在那里获得2英寸的SPF应该停止凝结。然后,您可以用一层修剪来覆盖泡沫。
对于整个周长来说,这将是一个好主意,但这会影响您的成品高度。也许增加一些地板加热也可能会有所帮助。虽然是能量猪。
gmtinyhouse,
只是为了增加乔恩(Jon)和阿科斯(Akos)所说的话:我认为添加绝缘裙子没有任何意义,除非您要加热拖车下的整个空间 - 这没什么意义。引起冷凝水的原因是内部空气与非常冷的材料(金属框架)接触。裙子的唯一目的是加热一个法兰。
