GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
Using closed-cell foam in a double stud wall
Joe St. Denis|发布能源效率和耐用性上
Joe St Denis
我们住在7-8区艾伯塔省中部。我们想建造一个带有步入地下室的1 1/2故事的房子。西部,北部,北部和南部地下室墙壁开放的湖边房屋。
I have spent hours reading on how to best insulate walls and ceilings (which I find can be and has been challenging). After reading many articles I was planning to build a double stud wall using 1/2 inch plywood on the inside stud walls which we could cover later with wood or thin gyprock. Use scissor trusts for a cathedral ceiling, also lined on the inside with plywood.
Then to solve many problems insulate both from the outside with closed-cell foam to within one inch of the surface to allow for venting cover with a rainscreen and install siding and metal roofing.
您的想法将不胜感激。
  1. Joe St. Denis||#1
    此外,它将解决任何空气密封问题,不需要空气屏障。唯一的额外密封问题是门,窗户和公用事业。
  2. GBA Editor
    马丁·霍拉迪(Martin Holladay)||#2
    Joe,
    Your suggested approach would work. It has two disadvantages:
    1.这很昂贵。建筑商选择建造双块墙的主要原因是,他们可以使用廉价且环保的绝缘材料(纤维素)。
    2.闭孔喷雾泡沫使用具有较高全球变暖潜力的吹风剂;这就是为什么绿色建筑商试图最大程度地减少其使用的原因。
    A house with double-stud walls and scissors trusses can have wall and ceiling cavities that are as thick as you want, easily accommodating almost any thickness of cellulose insulation.
  3. Expert Member
    Dana Dorsett||#3
    Putting half-inch OSB, detailed as an air barrier on the exterior side of the inner studs, sheathing the exterior with half-inch CDX and doing it all of the insulation with cellulose or blown fiberglass makes for a much cheaper, greener and more resilient assembly. The OSB would always be above the dew point of the conditioned space air, and when dry has a vapor permeance nearly as low as code demands for interior vapor barriers in Canada. When it's moisture content rises, so does it's permeance, but in a fairly linear fashion. CDX has a slightly higher vapor permeance than OSB, but becomes quite a bit more vapor open than OSB when wet, so as long as the siding is rainscreened it will reliably pass through any moisture that gets by the OSB.
    This is a fairly common stackup for PassiveHouse & PassivHaus designs that makes smarter use of the lower vapor permenace of OSB relative to plywood. Both are variable-permeance "smart" vapor retarders, but OSB is more vapor tight than plywood, making it a better choice as the interior vapor retarder for a plywood-sheathed assembly.
    Putting the OSB on the interior side of the interior studs just under the gypsum would work too, but it would have many more electrical & plumbing penetrations to air seal. Whether it's worth the extra trouble of putting it on the exterior side of the interior studs to gain the long-term and more reliable air-tightness is up to you.
    Cheaper than OSB would be to install a membrane type smart vapor retarder (Intello, MemBrain, etc.) directly under the gypsum, or on the exterior side of the interior studs (if you can figure out a good way to install it there in an air-tight fashion.)
  4. Joe St. Denis||#4
    Thanks for the advise. I will re consider and look at other options.
Recent Questions and Replies
