This Service (including, but not limited to text, content, photographs, video and audio) is protected by copyright as a collective work or compilation under U.S. copyright and other laws. You must abide by all additional copyright notices or restrictions contained in this Service.
You may create Web links to any URL on greenbuildingadvisor.com, including articles.
YOU MAY NOT COPY, REPRODUCE, DISTRIBUTE, PUBLISH, DISPLAY, PERFORM, MODIFY, CREATE DERIVATIVE WORKS, TRANSMIT, OR IN ANY WAY EXPLOIT ANY PART OF THIS SERVICE, EXCEPT THAT YOU MAY DOWNLOAD MATERIAL FROM THIS SERVICE FOR YOUR OWN PERSONAL, NONCOMMERCIAL USE AS FOLLOWS: YOU MAY MAKE ONE MACHINE READABLE COPY AND/OR ONE PRINT COPY THAT IS LIMITED TO OCCASIONAL ARTICLES OF PERSONAL INTEREST ONLY.
WITHOUT LIMITING THE GENERALITY OF THE FOREGOING, YOU MAY NOT DISTRIBUTE ANY PART OF THIS SERVICE OVER ANY NETWORK, INCLUDING A LOCAL AREA NETWORK, NOR SELL NOR OFFER IT FOR SALE. IN ADDITION, THESE FILES MAY NOT BE USED TO CONSTRUCT ANY KIND OF DATABASE.
0 Comments
Sign up Log in
