More than 600 days into the Trump administration, amid constant reports of regulatory rollbacks, there’s been surprisingly little damage to energy efficiency… yet. But now the administrative winds are starting to blow, rulemaking procedures are underway — with a couple of open comment periods — and we are working hard to hold onto the energy savings we have been helping to build.
The Obama administration had some remarkable successes on energy efficiency. Weestimatedthat its appliance, vehicle, and power plant standards alone should save over 10 quadrillion Btu per year by 2030 (equivalent to about half of U.S. home energy use), and should cumulatively save consumers over $2.5 trillion in energy bills by 2040.
How resilient are those policies and programs? Here are some local weather reports:
Vehicle standards are facing a gale
The Department of Transportation and the Environmental Protection Agency (EPA) recentlyproposedto roll back the fuel economy and emissions standards for cars and light trucks for 2021-2025 (EPA had alreadydeterminedthat the standards set in 2012 are too high), and to block California and other states from implementing higher standards. This would waste 14 billion gallons of fuel a year. The draft is open forcommentthrough October 26, and ACEEE already gave preliminarytestimony.
EPA is chopping away at the standards for heavy trucks as well, issuing aproposed ruleto exempt gliders (new trucks with old engines), and considering repeal of the standards on truck trailers. There already are lawsuits related to all of the vehicle standard issues, with a stay on the trailer standards.
Clean Power Plan
EPA last yearproposedrepealing the rule on greenhouse gas emissions from existing power plants, and recentlyproposeda much weaker replacement rule that would only seek modest efficiency improvements at the plants (and gave it a different catchy name, the Affordable Clean Energy rule). It is open forcommentthrough October 31. Meanwhile, the Clean Power Plan also is blocked by a court stay.
Appliance standards frozen in place
由于独特的法律条款,Department of Energy (DOE) cannot weaken existing standards, so most of the standards appear to be safe. But the agency also has not proposed a single update and has now missed a dozen legal deadlines. And four standards that the Obama DOE had issued but not yet published in the Federal Register remain in limbo after 20 months (DOE has appealed a court order to publish these standards).
Worse, DOE ispreparinga draft rule that could try to roll back one of the biggest-saving rules ever — a definition that applies 2020 light bulb standards to a wider range of commonly used bulbs. Mysteriously, a document on full repeal of the definition appeared on, and then quicklydisappearedfrom, DOE’s website. Such a rollback would be taken to court. DOE is also working onprocedural changesthat could weaken the program.
Manufactured housing standards
2016年能源部草案基础上达成共识agreement between manufacturers and efficiency advocates has never been finalized. Now DOE isconsideringa weaker standard or maybe no standard at all, while the Department of Housing and Urban Developmentconsidersweakening the existing HUD code for manufactured homes (in which the energy provisions have not been updated since 1994).
All of the above are proposed or potential actions. There have been a couple small final actions. HUDreversedits earlier support for Property Assessed Clean Energy (PACE) financing, barring the Federal Housing Administration from insuring mortgages on homes with PACE assessments. And DOE issued a requireddetermination(only a few months late) thatASHRAE 90.1-2016, the model standard for commercial buildings, saves energy. This will encourage more states to update their commercial building energy codes.
Meanwhile,federal energy efficiency programscontinue working despite roadblocks. Energy Star is still the leading mark of energy efficiency, and has set and updated some product specifications, despite a White House attempt to end it and a draft bill that would have gutted it. Congress seems set to pass level funding for the second year in a row. And although the administration proposed drastic cuts to DOE efficiency programs, Congress actually increased funding for this year when it finally passed a bill in March, and has slightlyincreasedfunding for next year.
Although the money is there, getting it out the door has been an increasing problem, made even worse because there still is not a Senate-confirmed assistant secretary for energy efficiency and renewable energy at DOE.
While the near-term forecast does not look good, we are working to limit the damage as much as we can. And as unpredictable as the course of a storm may be, we know that the one certainty about the weather is that it will eventually change.
Lowell Ungar is senior policy advisor at the American Council for an Energy-Efficient Economy. This post originally appeared at theACEEE Blog.
One Comment
California, god bless them, I hope they succeed. It would be a win for federalism.
Q for anyone with regards to the OTR diesel trucks. My understanding is that the introduction of DPF/SCR (Urea) resulted in higher fuel costs (net reduction in MPGs), increased maintenance expenses vs the pre-DPF/SCR rigs. Basically that on a mileage basis the trucks with the new tech don't emit significantly less NOX and just cost more to maintain/acquire.
From my own anecdotal experience the emission system on my diesel only lasted 50k miles.
I've also read that relatively small size of the PM emitted via DPF burn off is arguably worse than that PM w/out DPF since it travels deeper into the lungs.
Sign up Log in
