马特·梅尔顿(Matt Melton)住在华盛顿州中部,居住在一栋3岁的房子里,屋顶由结构性隔热面板(SIP)制成,厚度为12 1/4英寸。屋顶的音高非常低,仅1/2英寸12英寸,并且金属屋顶直接在SIP上施加,而在屋顶下没有空气通道进行通风。
建造房屋时,梅尔顿用胶带密封了屋顶面板之间的接缝,并涂在面板的底部。屋顶的顶部完全被剥皮的膜覆盖。梅尔顿现在说,在这两种情况下,胶带和屋顶膜的接缝似乎都不太粘。
今年,有麻烦。梅尔顿第一次注意到屋顶上有一个冰坝。更糟糕的是,他报告说,漏水在s饮之间的接缝中漏水,尽管泄漏出现在屋顶上,而不是房屋内部。
“现在,我想知道我是否应该在变暖后将所有屋顶拔掉,让东西变干,看看是否有模具,”他在绿色建筑顾问的问答帖子. “Then maybe replace with a better underlayment and a TPO roof?”
还有一个复杂的问题:梅尔顿已经卖掉了房子,现在正在从其新主人那里租用它。他们显然计划在5月占有。
梅尔顿应该如何处理这个发展中的问题?这就是这个问答焦点的问题。
现场访问是一个很好的第一步
GBA senior editor Martin Holladay makes five observations: installers used an interior tape with adhesion problems; there is evidence of air leakage at the seams between SIPs; it appears that melting snow on the roof caused by air leaks led…
一条评论
好文章
Thank you again for this Spotlight article. A standard truss roof with an open attic (insulation at ceiling height - no spray foam) is the least problematic way to do a roof. No debating that. SIP roofs require special details, tapes and procedures to make sure that they will perform for a lifetime. These details were discussed in the above article. Skipping these steps and/or details, is a risky endeavor. Following these details will result in a sound and lifelong roof assembly.
MBCI使站立的接缝金属屋顶的音高低至1/4:12,并保证它们可以防止泄漏。站立的接缝很高(通常为3英寸),它们通过使用夹子和金属子衬里将金属面板从甲板上抬起。接缝被夹住,锁定并密封到位。较陡的音高屋顶是排水的更好方法,尤其是在多雨的气候中,但是在沙漠或低降水气候中,低俯仰的屋顶可以使用站立的接缝金属屋顶,但必须使用护理和右屋顶面板。
再次感谢您的文章!希望那些寻求sip屋顶的人可以阅读和利用它。
登录or become a member to post a comment.
注册 登录
