Image Credit: Alex Wilson
一些节能策略包括我的开支ey: replacing appliances and lights with more energy-efficient products, tuning up a heating system, and insulating an attic, for example. Other measures don’t require any expenditure at all. Below is my top-ten list of easy, no-cost ways to reduce your energy use. If you’ve been reading my column regularly, these will all be familiar, but since it’s time for New Year’s resolutions maybe a quick review will give you the needed nudge to step up your efforts.
1. Drive less.对于我们大多数人来说,减少能源消耗的最有效方法是减少驱动。走更多或骑自行车 - 您将通过更少的花费和保持更好的状态而受益。与同事协调您的旅行,共享游乐设施。结合去城镇的旅行。使用公共交通。
2.关闭灯。效率最低的照明是当没有人在房间里时打开的光线。离开房间时养成关闭灯的习惯。
3. Turn down the heat.You don’t need a programmable thermostat to lower your temperature settings at night or when you head off to work; you can do that manually with a simple thermostat. Each degree of temperature setback will reduce your total heating costs by about 2%, according to the American Council for an Energy Efficient Economy; if that setback is for a portion of the day (say eight hours at night), the savings will be roughly proportional.
4.进行短淋浴。加热通常是北部气候房屋中第二大能源消费者,因此减少热水是节省能源的一种简单方法。这些策略之一是缩短淋浴。有些人还将流动滴落或肥皂减少热水(“军用淋浴”)时,将流动倒流。
5.用冷水洗衣服。洗衣机,尤其是较旧的装载型号,每个负载最多使用约50加仑。在冷水中洗衣服可以大大减少您的能耗。如果您必须用热水洗涤(并且要使衣服干净,热水确实可以更好地工作),至少将洗衣机用冷水冲洗。
6.在户外挂衣服或使用室内干燥架。而不是使用电动或燃气干燥机,而是在户外挂衣服。在冬天,您可以在室内挂衣服,并从晾衣衣服提供的湿度中受益。
7.有效地使用洗碗机。运行全负载的机器。刮掉食物碎片,但是使用相对较新的洗碗机,通常不必在将其放入洗碗机之前进行预磨菜。如果您必须冲洗(有时是必要的,尤其是对于较旧的洗碗机),请使用冷水。
8. Block drafts under doors.当我长大时,我们的房子(1710年建造的木屋)总是很宽容,我们在门底,尤其是在晚上使用了一个充满沙子的“蛇”。我今天看不到这些,但是如果您的门在门槛上没有紧密密封,这些蛇仍然很有意义,并且它们很容易从废料材料中制成。
9. Eliminate “phantom loads.”Most of us have lots of hidden electrical loads in our homes: cell phone and tool chargers that are always plugged in, televisions that are never totally “off,” and wireless routers that draw electricity 24-7, for example. Unplug these devices when not in use, or plug them into power strips that can easily be switched off.
10. Extend your energy savings to your workplace.如果您成功地在家做简单的事情,请不要止步于此。携带您的节能实践来工作!
All of these measures are free. But they do require a little more awareness and forethought. Wishing you the best for the New Year!
P.S.我很高兴地报道说,我确实在圣诞节上收到了SNO机织,这是我上周的圣诞节礼物专栏中提到的轮式,后卫的雪铲。组装大约一个小时,我现在焦急地等待暴风雪来尝试一下。等不及了!
I invite you to share your comments on this blog. You can alsofollow my musings on Twitter
3条评论
Need for right programs for residential customer to change
与改变行为有关的好列表。我们的研究表明,不到2%的房屋持有将采取行动来做您上述建议的事情,并将减少约5%的能源消耗,以减少参与的1-2%的家庭。要正确改变行为,需要一些激励(智能胡萝卜),其中应包括金钱($),正确的信息,这是正确的事情,以及处理自我/竞争精灵/环境道德的方法。
应为不同的邮政编码修改激励措施。目前,只有2-3个公用事业(在3000个公用事业中)在此领域提供了程序。
Regards,
Hossein
智能胡萝卜
好术语...好概念
谢谢霍斯辛
Sno Wovel
I guess someone really wovels you...
登录或创建一个帐户以发布评论。
注册 登录
