GBA Logo horizontal Facebook LinkedIn Email Pinterest Twitter Instagram YouTube Icon Navigation Search Icon Main Search Icon Video Play Icon Audio Play Icon Headphones Icon Plus Icon Minus Icon Check Icon Print Icon Picture icon Single Arrow Icon Double Arrow Icon Hamburger Icon TV Icon Close Icon Sorted 汉堡/搜索图标
Community and Q&A
Best way to insulate old home
Fiorenini| Posted inEnergy Efficiency and Durability在
I have an older home built between 1850-1870 and while it has been updated over the years, it is in need of new siding so I am trying to determine the best way to insulate, wrap and seal the house properly. I plan to replace the old siding with LP siding and open to any suggestions and ideas. I have heard many different ideas as to how I should be done so I am hoping to get some clarification. I live in Maryland and I am in Zone 7.
thank you in advance,
Frank
  1. John Michelotti||#1
    Isn’t Maryland in climate zone 4 or 5?
    Similar situation for me. 1880s Victorian covered with aluminum siding.
    1. GBA Editor
      Brian Pontolilo||#3
      Most of Maryland is Climate Zone 4A. You can find that info here:https://codes.iccsafe.org/content/IRC2018/chapter-11-re-energy-efficiency
  2. Fiorenini||#2
    I thought we were 5 as well but a search earlier said its 7. Where should I check for clarification, I may very well be wrong.
    Frank
    1. Expert Member
  3. GBA Editor
    Brian Pontolilo||#4
    Hi Frank.
    You should try to accomplish a few goals including air sealing and insulating, while making sure that your water-management details are working (water-resistive barrier, flashing at windows, doors, and other penetrations).
    There are lots of possibilities, and I'm sure you'll get a bunch of opinions, but it would be helpful for us to know what's behind the existing siding and what is going on inside the walls.
  4. Fiorenini||#5
    Hello Brian,
    I have not yet pulled any existing siding down but from the very few spots that I have been able to see from interior projects, i have found that there are random areas of insulation and studs do need seem to be evenly spaced, there will also be some damage that I will take care of when the siding is down. My main questions are around the specifics around what I should be using. I am willing to spend extra to buy all of the necessary items for the job. I also plan to start on the rear of the house that is roughly 500sq ft. Is fiberglass insulation better than foam board insulation, is Tyvek better than felt paper, is a rain screen needed? I would hate to spend money and realize that I did not get the right materials for my area and application. I am also not sold on LP, I have used Hardie in the past and not committed to either.
    Thank you for reaching out,
    Frank
Community
Recent Questions and Replies
