更改为minisplit问题
亚历克斯·D|发布机械性能在
So I’ve been considering converting to an all electric house since solar is looking a lot cheaper these days and due to a combination of not having AC and finding out this week that my flexible ducts in the attic have been chewed up by rats I’m looking at installing a multi-head mini split. I’ve got few questions now that I’ve gone through the work of doing I think a mostly accurate manual J at coolcalc.com
之前我掏了进去,我在圣何塞CA,这里是顶级Calcs(计算),我有:
加热面积: 1401年
冷却面积: 1401年
加热体积(以上等级CF): 14010年
冷却量(以上等级CF): 14010年
裸露墙面面积(SF): 1190年
暖气BTUH: 13791
冷却BTUH: 18184
CFM: 809.
合理的冷却: 16023年
潜伏在冷却过程中: 2161年
SHR: 0.881
这1401平方英尺的我〜1 000大房间是生活,厨房和用餐(3间卧室都很小,最大的是12〜14×)。
我的房子被对半分割基本上与新建筑2×6 R-19的墙壁和然后100岁结构没有隔热壁是非常厚的(内 - >出,板条,灰泥,全尺寸2×4腔,1-2“隔板墙板,更现代的木质墙板,壁板灰泥)。下方岁半的房子我也有〜7'高的地下室,我刚打完气封,增加保温到我希望与包膜会有所帮助。
起开始如何选择一个小分裂:)。所以找这个报告我只需要从我的小型分体式系统加热的〜14K BTU的?that seems awfully low for a house that had virtually no attention to air sealing (I’ve done a decent job in the attic and the remodel had all the top plate and bottom plate penetrations spray foamed) and half the walls insulated – attic has r-30 and crawl-space (about half of my floor square footage) r-19. If this is the case, laughably the HVAC contractor installed an 80K BTU 96% AFUE furnace (Goodman Model: GMSS960804CNAA) in the attic with insulated flexible duct, and since starting to learn more about all of this late last year I’ve had a feeling that I’ve been oversized since my furnace always seems to run in short bursts. Now, only needing a 20K mini split would be great news (and I guess is close to a rule of thumb I’ve seen of ~21K BTU for ~1400 sq ft?) since I was expecting something closer to 30K or 36K BTU, but I wanted to double check that my numbers seem reasonable?
此外,我最初在大房间里放了一个头,在两个最大的卧室里有三个房间的calcs:
GreatRoom:
总冷BTUH:
15903年
总加热BTUH:
8663年
卧室1(1.5外墙,r-19):
总冷BTUH:
1,335
总加热BTUH:
975
BedRoom2(1个外墙,没有绝缘):
总冷BTUH:
808.
总加热BTUH:
661.
然而,我在其他地方读过Dana的评论,头在更小的房间没有意义,因为你结束了短周期和失去效率。
此处未列出的是我有两个外部绝缘的墙壁,但在很大程度上受到了一棵橡树是一种常绿阴影微小〜9×11的卧室。我也没有列出地下室我只是绝缘,因为它只有在冬天寒冷的获取和几乎没有得到在夏季超过80个。我的主要问题是:
1)难道一个多头配置工作?
2)大房间(50 '长x ~12 '宽)里只有一个人,我该担心吗?
3)我应该关心的是小房间永不舒服,因为它是非绝缘和泄漏?
4)从表面上看,我的数字还算准确吗?
5)还有什么我俯瞰?
另外,作为一个侧面说明,如果它很重要,我打算做安装自己,然后雇人疏散,泄漏测试和充电系统,希望这似乎并不疯狂。我大部分时间迷失在HVAC承包商所有信仰学习如何事情应该主要做,看到安装我付了之后。
  1. 德文 - 卡尔森||#1
    这些负荷不是太离谱,但对我来说确实有点高。如果你把阁楼和地下室密封起来我也不会夸大漏气的程度。我的旧的1200平方英尺的鳕鱼角,原始矿棉在它的2x4的墙壁有一个测量到的热损失~20k btu/h @ -12.3°F和热增益~6k btu/h @ 80.9°F。
    2017年,ASHRAE在圣何塞的设计条件规定,99%的加热DB为37.7°F, 1%的冷却DB为87.8°F。如果你的加热负荷达到10k btu/h,我将感到惊讶,这将使你目前的设备800%+超大。除非他们认为你需要4吨空调,否则他们的设备选择没有多大意义,因为生产线上的所有小熔炉最多支持3吨,所有大熔炉最多支持5吨。好的暖通空调承包商肯定很难找到。
    我不会把一台专用压缩机的一个头放在一个负载<1k btu/h的房间里,更不用说一个多分裂的房间了。如果有地下室可用,我建议使用单管道单元。管道单元还可以让你调节小卧室和地下室本身,以及更好地解决大房间。如果没有任何气流,绝缘不好的卧室会很不舒服,特别是如果门关闭了很长一段时间。
    如果你没有当地的设计师,有几家公司在互联网上工作,他们可以帮你起草计划,你可以从当地的承包商那里工作,或者把计划交给他们安装。
  2. 亚历克斯·D||#2
    由于德文。
    我承认我不知道微型管道裂口里面装的是什么,但我相信他们还是需要一个回风静压箱和供给管道,对吧?我对此有点担心,因为在我的地下室,头部空间是溢价,现在我已经建立了地板,有7'或更少的头部空间(是的,我的托梁大小不同:D)。我也觉得只安装2-3个头会稍微容易一些,但我很高兴能接受教育。
    我的两间大卧室正好在1K BTU负荷的顶端,所以也许脑袋小就可以了?虽然我似乎找不到任何低于7K BTU的头,但有没有哪头可以挂在隔断墙上,同时调节两个房间的空气?这样的东西对我的两个最小的房间很有用,因为他们共用一面墙。
    显然,当涉及到设计暖通空调系统时,我有点超出了我的能力范围,但我有动力让我的系统走出无空调的阁楼,同时也摆脱天然气。我只是不希望这样做的方式导致我们在冬天争购插件加热器,或导致我计划的~4KW阵列不足以使我的电费接近零千瓦时。
