专用ERV聚氨酯管道中的热量mp System
你好,
HVAC推荐用于混合ERV系统,因为我正在进行一个全套加热热泵系统(三菱Zuba Central)。他们建议只在浴室和厨房中做排气系统,而是通过使用加热/冷却管道供应新鲜空气。他们通过这样做说,它会节省成本,因为必须安装较少的管道,并且可以使用小的ERV。
Is this recommended or should I stick with my original design by having a fully dedicated duct system for both the ERV and the heating/cooling system?
Arnold
完全管道和独立的通风系统仍被认为是最好的。是否足以满足成本差异取决于您。请注意,他们提出的系统可能会花费更少安装,因此运行的成本更高。
https://www.buildingscience.com/documents/information-sheets/info-611-balanced-ventilation-systems
Hi Trevor,
Thank you for your input. My understanding was the same that a shared duct ERV system would cost more to run due to the duct size being large than what is required for the ventilation system.
HVAC承包商还提到,如果我使用专用通风系统,他需要安装2KWH预热器,但如果我用加热系统将其纳入其中,则不需要一个,因为进入空气将用再循环中继稀释。
The all makes since except for the shoulder season or during mild summer period during when neither the heat or AC is running.
我缺少一些东西,还是这只是一个暖通空调承包商试图做典型的安装而不知道这个房子会高效?
Arnold
您不需要大多数ERV的预热器。什么是模特?
In the shoulder seasons, the air handler will still need to run. Even in the heating/cooling seasons, it needs to run a lot more than it would for heating/cooling purposes. The heating/cooling requirements will rarely align perfectly with ventilation needs, which is why keeping those ducts separate is preferable.
你打算一直跑炉风扇吗?检查号码 - 例如炉扇关闭,您的房屋需要100 CFM,闭门门主卧室随附10%的空气(基于加热/冷却负载)。它只需要获得10个CFM *的新鲜空气 - 您需要大约30个CFM的新鲜空气,用于两个人的健康二氧化碳水平。加热/冷却配电比率和通风比例不同 - 共享系统无法做到的东西。
* - maybe. At low volumes, the over-sized duct flow ratios change in hard to predict ways.
Hi Jon,
I was not planning on running the furnace fan 24/7 and for the ventilation system, I was thinking it would run for sometime like 20 minutes every hour.
Arnold
我经历了一些数字,一个闭门的门卧室需要大多数重新循环的空气,而不是100%新鲜空气。例如,30 CFM的新鲜空气与90/10混合的Recirc和新鲜空气的100 CFM。一直少于风扇的任何东西都不太可能为合理的闭门卧室CO2提供足够的气流。
注意,蒸发器线圈上的多余气流对潜伏性能具有很大的负面影响。当压缩机低/关闭时,理想情况下,气流将在蒸发器周围旁路 - 但我从未听说过这个系统。
它听起来最好是拥有专用通风系统并保持其自身的加热/冷却。
我只需要弄清楚它是否值得额外的成本。
Thanks,
Arnold
I'll throw out another option that could be cost effective. Use shared ducts for the majority of ventilation air distribution and a supplemental spot ERV in problematic closed door bedrooms and offices.
大多数调制热泵运行鼓风机24/7,只要您的电源正确,您通常不必担心足够的空气变化。通常不需要任何定时器。
使用杂交管道选项,您可以随时在卧室内包含陈旧的空气拾取器。这种方式即使空气处理器关闭(即肩部),您将在关闭房间获得空气变化。从房间绘制陈旧的空气并不像直接供应新鲜空气,而是足够好的空气。它还可以节省您必须用ERV互锁空气处理程序。当空气处理器运行时,电源管道通过房屋分配新鲜空气,当空气处理器关闭时,新鲜空气通过返回寄存器供应到房屋。
它们还调制风扇,然后该风扇不提供几乎足够的混合气流,例如我看的例子。另一方面,有些人可以让卧室门打开。
