社区and Q&A
How to best insulate a new truss roof?
user-2435739|发布能源效率和耐用性上
I am going to build a new home in northern Idaho, zone 5. It will be a ranch house with walk out basement. Most of the house will have scissor trusses, 8/12 pitch upper and 4/12 pitch lower. With the exception of two shed dormers that will be stick framed. I originally thought of closed cell spray foaming the entire underside of the roof deck for an unvented attic space.
There will be a few areas which will most likely have 9′ flat ceilings such as baths & closets.
Would this be the optimal approach as opposed to using batts and blown in on top of that and venting the attic?
How much of a difference between the two methods would it be if the foam proves to be too cost prohibitive?
Also the garage roof will be walled off from the main house under the roof line. That demising wall will be insulated how ever I do the main roof. The garage will be built with attic trusses for storage over the garage. The garage will probably be heated most of the time to be just above freezing unless we have work to do in the garage for shorter periods of time. For the garage ceiling I was thinking of 1″ foam and 5/8″ FC drywall under that and batts above for the ceiling area all around the outer perimeter of the storage area above. And then encapsulating the storage area with 1″ foam, drywall and batts and then venting the garage part of the roof above the storage area. Does this sound workable?
  1. 用户1072251||#1
    Forget about using foam. Instead, buy raised heel trusses which provice, at a minimum, 26" below rhe sheathing at the eaves. Install and seal a vent chute and 18"-20"of blown cellulose. (allow at least 10-15% for settling) You might need baffles to keep the insulation from sliding down, but your installer should be able to figure that out. You can frame the flat ceilings under the scissors, so they'll be warm storage.
  2. GBA Editor
    Martin Holladay||#2
    James,
    Scissors trusses can be tricky to insulate, because loose insulation materials don't generally like to be installed on a slope, unless they are fully encapsulated by rigid materials.
    You should talk to your insulation contractor about your options, because there is no use in recommending a method that your local contractor can't perform.
    通常,只要执行通风细节(如果需要),任何绝缘方法都可以起作用;只要对气密的关注。只要绝缘的R值满足或超过最低代码要求;只要精心执行安装,就没有空隙。
Recent Questions and Replies
