内部泡沫绝缘与外部
vanhanbr2|Posted inEnergy Efficiency and Durability上
我以为我已经弄清楚了。我在威斯康星州中部,第6区,我正计划在2×6结构上,(2)1英寸层的外部多丽体层通过Fastenmaster的规格,由3/4英寸的毛茸茸条持有。Hardieboard仅需要3/4英寸的螺钉穿透力,就可以了……但是所有的5/4和4/4装饰(Frieze,Band Corners)由Smartwood,Miratec,Azek,Azek,Certainteed制造,需要1 1/4渗透。Using vinyl siding with basic corners are about the only option which would be fine, but I would still have to foam between the furring stips and it still doesn’t provide a solution for bump-out windows with decorative trim that more or less has to be made with 4/4 boards. Exterior foam also makes cultured stone nearly impossible, and I have yet to find a manufacturer that supports exterior foam (2″ anyway.) Short of using 2×4 furring strips (still not supported by Certainteed), there are no manufacturer approved solutions.
The only solution I can come up with is to ditch exterior rigid insulation and put interior rigid insulation between the studs and drywall. But I need a little guidance.
1)我仍然需要内部蒸气屏障吗?我正计划在螺柱之间使用密集的包装纤维素,将隔热材料保存的最佳方法是什么?
2)我仍然需要2英寸的泡沫,还是可以减少?我在想,如果我使用1/2英寸至1英寸,我可以保存我们的毛茸茸的条。
3)我是否还应该尝试保持外部结构护套密封(即胶带接缝)?还是我需要使干燥到外部更容易?
  1. 用户901114||#1
    只是在6区的螺柱上进行了一些内部泡沫Tuffr Polyiso。
    1)无VB。您可以使用Insul Mesh将纤维素固定在中。或在泡沫中钻孔并将其吹进去。我和Roxul Batts一起去了。
    2)我使用了1英寸。泡沫接缝。我不使用绑带。悬挂蓝板时的主要疼痛来找到螺柱。还可以通过省略空间绑带而在Radiant R3上丢失。并在分区后面运行泡沫。
    3)是的,您仍然应该尝试使胶合板的空气紧密,以使其均匀干燥。我从内部使用了填缝。
    回想起来,我希望我能在外墙上使用2层2英寸泡沫。会终止更多的热桥。由于此,我每年会损失什么?谁知道..
  2. DQK4P49B9E||#2
    I am in Southern Maine and have found a way to meet Certainteed's warranty as well as prevent thermal bridging. Hunter panels make a product called Nail Board or Nail Base. It is a 4x8 sheet of polyiso of your desired thickness (I have been using 2") adhered to a 7/16" OSB. , It get fastened with a factory recommended Headlok screw. From an installation stand point, you are adding foam to the exterior and re-sheathing that entire building. Certainteed has an amendment for SIP's paneling that allows you to have 1/2" of purchase, fastened minimum of every 12" that this falls under. I went to a cement fiber certification held by Certainteed just to have this method approved and they said it would be covered under warranty. From a cost standpoint a 4x8 sheet of 2" nail base costs me $46 dollars. A 2" sheet of polyiso cost me about $42 not including the OSB or Strapping. From an installation standpoint it goes up faster than strapping and you don't have to worry about nailers around doors and windows other than the jams, which you would have to deal with anyway.
  3. vanhanbr2||#3
    问题不是壁板,而是较厚的装饰。我尚未找到一种批准的方法,用于使用2x材料作为毛茸茸的5/4修剪。如果我这样做,我要么需要使用2倍毛rring作为所有东西,要么在拐角处使用3/4“少量泡沫,以补偿2倍的毛茸茸,而在拐角,frieze,band等上进行2次毛茸茸的泡沫。如果我使用3/4“少量泡沫,我遇到没有足够的泡沫来满足代码。此外,很难匹配所有不同的厚度。
  4. GBA编辑
    马丁·霍拉迪(Martin Holladay)||#4
    布莱恩,
    问:“我唯一能提出的解决方案是抛弃外部刚性绝缘材料并将内部刚性绝缘放在螺柱和干墙之间。我是否仍然需要内部蒸气屏障?”
    A.不。
    问:“我正计划在螺柱之间培养浓密的包装纤维素。将隔热材料保存的最佳方法是什么?”
    答:您可以安装可渗透的网络,也可以在安装干墙后通过干墙的孔将绝缘吹拂。有关更多信息,请参阅如何安装纤维素绝缘。
    问:“我仍然需要2英寸的泡沫还是可以少逃脱?”
    答:我不建议您切割刚性泡沫并将其插入螺柱之间。那是一种挑剔且耗时的方法。您最好使用闭孔喷雾聚氨酯泡沫进行闪存和填充安装。是的,您仍然需要至少2英寸的泡沫。
    问:“我是否应该试图保持外部结构护套密封(即胶带接缝)?”
    答:我认为,是的。限制空气泄漏总是有意义的。
    问:“还是我需要使干燥到外部更容易?”
    答:建造故意泄漏的墙是一种非常糟糕的方法,因为泄漏的墙壁可能比紧墙更风险。如果您的墙壁泄漏,您最终可能会出现更多而不是更少的冷凝问题。
  5. vanhanbr2||#5
    马丁,我承认我的措辞不是最好的。我计划在干墙下方安装泡沫----螺柱,在内侧。我仍然想尽可能限制热桥。我相信,以这种方式隔热的屋顶仍然需要发泄,这就是为什么我在墙壁上问的原因。我的印象是,如果以这种方式安装泡沫,则不需要那么厚。
  6. GBA编辑
    马丁·霍拉迪(Martin Holladay)||#6
    布莱恩,
    您可以根据需要安装内部刚性泡沫。如果您走那条路,请确保在壁板和护套之间包括通风的气隙,以帮助您在冬季获得水分后在春季干燥。
    我敢肯定,与外部泡沫相比,使用内部泡沫时,在RIM托梁和分区交叉点上的隔热细节更难详细说明。但是,如果您仔细考虑每一步,就可以解决细节。
  7. 布鲁克||#7
    布莱恩 - 我认为您应该坚持外部泡沫。将大约1英寸的胶合板和撕裂到适当的条上,以在您需要附加钉子的第一层中使用。...用胶带密封,好像是泡沫板一样。我不必担心R-的损失在那些小区域中的价值。您“在边缘上ni缩”。...如果您能够建模这种泡沫的损失,您会发现它没有太大的不同。您需要先实用。我认为,您仍然可以通过使用外部泡沫来获得更好的信封,而不会与我认为内部使用泡沫板所需的许多空气密封/绝缘细节融合在一起。
  8. Vanhanbr||#8
    感谢您的建议。我花了一些时间考虑您的建议。1英寸胶合板很难进入我的区域。2层的1/2胶合板不加1英寸。甲板板的厚度为1英寸,因此可能可行,但是虽然固定螺钉的额定额定为接触。不过。请记住,这是一个小屋风格的房屋。有盒装窗户,正常窗户周围的所有装饰,带板,饰面板。这一切都需要更厚的材料。最初,我考虑使用1英寸泡沫,1/2“泡沫,然后是1/2胶合板。3/4“毛茸茸的条和1/2”胶合板将满足1 1/4的需求。有了这么多层,很难将其整体放在一起,然后毛茸茸的刺痛。
  9. Ibilisi||#9
    为恢复这个线程而道歉。但是,我也在第6区和1931年的灰泥房屋中。我们正在翻新并在现有的车库上为房屋增加一部分。我们曾在室内旁边的挫折中加入祖父,但我们不能进一步进入侧院。
    我认为,遵循有关泡沫板的“能量书呆子”帖子中的建议仍然是谨慎的。但是,我有点担心使用灰泥包装新的添加。我不相信灰泥会使护套充分干燥。
    两层# 15觉得联合国吗der stucco going to create enough of an airspace/drainage plane for a wall with interior iso and cellulose in a zone 6 (Minneapolis) Or would it be better to simply use an alternative cladding with rainscreen to ensure sheathing dryness.
  10. GBA编辑
    马丁·霍拉迪(Martin Holladay)||#10
    加勒特,
    我的规则是:如果您将灰泥安装在木结构建筑物上,则始终需要灰泥和墙壁护套之间的通风气隙。
    更多信息在这里:要安装正确的灰泥,包括气隙。
登录或创建一个帐户以发布答案。
Community
最近的问题和答复
