GBA标志水平 Facebook LinkedIn 电子邮件 Pinterest 推特 Instagram. YouTube图标 导航搜索图标 主要搜索图标 视频播放图标 加图标 -图标 图片图标 汉堡的图标 关闭图标 排序
我对“梦想之屋”墙壁的最新想法
杰里莱伯勒|发布了能源效率和耐用性在
我梦想中的房子将位于密歇根州的北端,俯瞰着航运通道。背面朝北,有很多窗户,我知道热量损失很严重,但这正是老板想要的。好消息是正面,街道一侧,将面对正南,可以持有大量PV。我将努力追求卓越的气密性,目标是r60天花板,r40墙壁,r30地下室墙壁和r30地下室平板下面(使用珍珠岩)。我将结合一个砖石加热器,但加热三菱高温迷你分裂。我看了那么多的墙,我希望最终确定“那一面墙”。双螺柱框架2×4 16″OC与3 1/2″之间的墙壁。我将计划使两者的承重,以适应我的大屋顶和雪荷载的要求,在另一篇文章中讨论。为了取悦老板,外面一定是砖做的!我将使用Ambrico EZ墙,一个薄(1/2″)砖粘在钢基板。 Under the panels is Greenguard DC14, a 1/4″ XPS product that has drainage channels on both sides, a low permeability to block solar driven moisture and add r1 to the wall. Under the DC14 is Tyvec covering 1/2″ structural rated fiberboard that adds r 1.3. The stud cavities are filled with R15 Roxul comfort bats the inter wall space is filled with r15 Roxul comfort bats for steel studs. The inner wall, is sheathed on it’s outer face with 1/2″ plywood and has an interior service cavity filled with Roxul r 15 bats.. The interior is 1/2″ drywall. I’ll use aligned studs for greatest condensation immunity in winter. The plywood will be carefully detailed as an air barrier and is the only moisture control layer. With a mid cavity r value of 47.83, ignoring drywall and air films. and a mid stud r value of 26.6 at 20% framing fraction, which I’ll try to beat by adopting principals of advanced framing even though I’m 16″ OC with double top plates, I calculate r 41.2 assuming pure 1 dimensional heat flow and 40.9 assuming the plywood is a constant temperature plane allowing unlimited crosswise heat flow in the plywood, like it had an aluminum foil layer. At 25 % the results are r39.83 and r38.6 And the wall is only 12 3/4″ deep including brick. The construction sequence will be a bit unconventional as the outer wall will be erected unsheathed and remain so till after the first round of air sealing testing ( which may begin with temporary ” plugs” in the windows. I’m working on details of the transition from concrete basement to wood walls trying for minimum heat loss economically. I’d like to consider the wall plan finalized so if you see that I did something dumb PLEASE speak up.
加入建设科学专家的领先社区
    杰瑞,
    如果我理解正确,你计划用钢螺柱建造一个双螺柱墙 - 或者也许你使用的木螺柱,但是用设计为钢螺柱设计的roxul产品绝缘木钉?如果后者是正确的,您应该意识到用于钢形壁的绝缘宽度比用于木框架墙壁的绝缘宽度宽。我建议您使用正确的宽度绝缘,了解您计划使用的螺柱类型。
    看起来好像你的双螺柱墙都将用纤维板护套。您计划将墙壁与钢板覆盖着粘贴的薄砖。我担心这些钢板造成外部蒸汽屏障。我怀疑的是Greenguard DC14(“一个1/4英寸XPS产品两侧的排水通道”)将提供足够的空气流量,以摆脱将在那些钢的内侧凝聚的所有水分面板。
  2. 露西Foxworth.||#2
    杰瑞,
    你正在经历完全相同的想法。你一直在你脑海中建造房子很长一段时间,对吗?不同之处在于您实际上建立了一个家。建筑工地听起来很漂亮。
  3. 杰里莱伯勒||#3
    露西,
    是的,我一直在“建造”我的梦想房子,无论是在我的头上和纸上,大约一年时间,我想这是很长一段时间。我建造的房子,当我更年轻和笨拙时,讽刺地实际融入了双层墙。但它们是内部垂直墙壁和外倾斜的墙壁,以创造一个“曼萨德”屋顶。虽然它创造了令人印象深刻的外观,但是在二楼的弯曲山上墙壁上,这是一个真正的皮塔,粗糙的木匠,我,建造,它是一只深渊的能量猪,。我建立了整个双层壁组合,使用我的手工制作的桁架'铆钉',包括弯曲的护套,悬垂的拱门以及窗户的弯曲顶部睡衣,甚至屋顶“在甲板上”,然后抬起大会然后完成外角在外面的梯子上。一个过程我肯定不会重复!
  4. 杰里莱伯勒||#4
    谢谢你看到这个!关于螺栓,他们将是木头,如果我用钢是多么的热灾难!我的计划是使用3层r15 Roxul,外层是木螺柱版本,中间层是在两螺柱线条之间的钢螺柱产品,利用它额外的宽度来填补每个螺柱后面的空隙。内层将再次是木螺柱版本的Roxul..换句话说,我计划在没有螺柱的地方使用钢螺柱绝缘。钢面板被刺穿,以提供定位砖的标签,所以他们充满了洞,创造了一个相当不完美的蒸汽屏障,这就是我使用DC14的原因。此外,根据制造商的说法,面板的压花相当深,在两侧提供一个通道,液态水排出。实际上,我将DC14的排水路径和面板的路径相邻在面板的内部。再次谢谢你。
登录或创建一个帐户来发布一个答案。
