社区and Q&A
To get R-49, can faced R-30 be layered on top with R-19?
James Stufano|发布General Questions上
I had asked a question yesterday on spray foaming under the deck for a long single family house. It seems no mater how you twist the options, the math shows just for the roof insulation is over $21K so almost 30K to insulated this 2000 sf new construction house. And 30K is after I removed some of the insulation steps to do myself.
I started looking at insulation that is available (both faced and unfaced) I started looking at fiberglass and Rockwool that I could work with since the ceiling between the 1st floor and attic is 10 inches deep – 24 OC trusses.
Under the roof deck is also 24 OC and 10 inches deep.
So looking at the pieces of the puzzle, my question is if I put face R-30 in the ceiling, can I then overlay R-19 unfaced over the installed R-30 below to come up with R-49. Doing it this way is only 10% of the closed cell option – yes less than $3000. If figure if I do it this way, I cut down dramatically on the insulation costs and I noticed I am not hearing from the installation installer after suggesting this by email. I would like to add I dont want to spray the fluffy stuff over the R-30 as I think it’s messy but I am open to other ideas. Thanks in advance.
  1. Expert Member
    Zephyr7||#1
    Yes, you can layer batts the way you describe. You want to make a cross-cross pattern with the upper layer laid perpendicular to the lower layer to minimize convection currents between batts.
    Bill
  2. James Stufano||#2
    Thank-you Zephyr7
    1. Expert Member
      Malcolm Taylor||#3
      James,
      I answered your last post but completely misunderstood what type of roof you had. It's probably my fault but I'm completely lost. What is your roof assembly from top to bottom? How do these two 10" cavities relate?
      1. Expert Member
        Zephyr7||#4
        I’m assuming the OP has a typical open attic floor formed by the upper level ceiling drywall and the lower chords of the roof trusses.
        From the question the OP posted in this thread, it doesn’t sound like a hot roof arrangement.
        For the OP: you should probably clarify exactly what you have. If Malcolm misunderstood what you had in a previous thread, I might have too in this one. It’s important to get this right so that you don’t have problems.
        Bill
  3. James Stufano||#5
    Thanks for asking for details. The house is a one floor 26x84 rectangle with 12 foot ceilings. The architect used what is called attic trusses that are designed with 2x10 rafters along the top with a 12 pitch, and 2x10 on the bottom, that makes up the ceiling for the first floor. Basically it has a barn/ modern ranch look. I was going to have spray foam R-49 on the gable ends and the under-deck of the roof in the 2x10 rafters but the quote of 21-22K is a lot of money so I started retinking the insulation. Because these area attic trusses, the center of the attic is a full walk up and it looks like a 8 to 10 foot wide bowling alley with 2x4 studs 24 oc on each side of the bowling alley. There is one Anderson Series A window on each end gable side. There are about 44 or 46 trusses that are 24 oc. The sheathing is on the roof and it is shingled. The town inspector wanted a ridge vent on the top so I am glad he asked for it as I can now let the underside of the roof breath with open soffits rather than having them foamed in. BTW I am in Zone 5.
    今天研究这一点,我注意到面对9.5英寸厚的R30 FG板条将完美地搁在1楼的天花板上,这是屋顶桁架的2x10底部to骨,也是阁楼地板。然后我的问题是在我在阁楼地板下的天花板上填充R-30之后,我可以在阁楼上,在2x10 rafter楼层的顶部放置R-19,以获得R-49。它完成了相同的R49,屋顶呼吸,我不必用泡沫做上述山墙,且小于3k vs 22k。我还会在某个时候隔离中央阁楼巷,这是一个大正方形,这意味着它们的侧面是2x4的侧面,顶部是2x4横螺柱,这将使该小巷区域为平坦的屋顶。我还将隔离山墙末端的部分,这些部分的窗口落在本节中。
  4. DCCONTRAIRARIAN||#6
    Do you want the attic to be inside or outside of your conditioned space?
    1. James Stufano||#7
      Basically it's 50/50 - The center of the attic will be the only usable space, which I described as a 10 foot wide x 8 foot tall bowling alley that is 84 feet long with a Anderson Series A window on each end. The stairs from the first floor to this walk up attic space is about 1/3 of the 84 feet on once side and 2/3s on the other. I may use the 1/3 side for an office and the HVAC person was tinking of one Mitsubishi air handler in the 1/3 side and one one the 2/3 side. This is 84 foot long center section has a subfloor at the moment and the two sides opposite the alley walls is the floor rafters from the trusses.
      The two opposite sides of this center alley has a sloping roof from 8 to zero and will have no use. Basically I was originally going to spray foam the entire roof and gables which looking back would gain no additional space beyond the center alley. These two sides of the center are sectioned off by the 24 oc wall on each side of the alley. If it gets too complicated in the attic, the HVAC can be installed in the full walkout basement under the 1st floor I'm thinking.
  5. DCCONTRAIRARIAN||#8
    所以建筑信封穿过the ceiling in the edges, up the walls between the edge and the center, and in the center it goes across the first floor ceiling for 8', up an 8' wall, across the attic ceiling for 10', down an 8' wall and then across another 8' ceiling?
    Where it's running over ceilings it's perfectly fine to roll out two batts of insulation perpendicular to each other, that's done all the time. You should also price blown-in, that's the other really common way of doing vented attics. I would make sure the attic outside the insulation is vented, and that the airflow isn't obstructed. Since this is a somewhat tricky shape you want to make sure there is good air sealing for the entire length of the envelope, and that where the ceiling joins the first floor walls there is continuous insulation and air sealing. The other thing to look at is the vertical walls in the attic, you may want more insulation than on the exterior walls because the vented part of the attic will be pretty hot in summer. They should be pretty straightforward to put foam sheathing on the exterior and either batt insulation or blow-in in the cavity.
  6. Expert Member
    彼得·恩格尔||#9
    In this arrangement, air sealing the connection between the vertical walls of the attic "alley" and the floor joists is super important. You don't want to allow unconditioned attic air from the triangular spaces to blow into the floor cavities under the center of the attic.
    You should read this article://m.etiketa4.com/article/insulating-behind-kneewalls
  7. Expert Member
    Zephyr7||#10
    I would put rigid foam on the outside of those studs on the sides of the “bowling alley”, and be sure to air seal everything all the way to the ceiling drywall under that space. I would use blown cellulose for all of the attic floor outside of that “bowling alley” area. I’d put batts between the studs on the sides of that “bowling alley”.
    If you are going to put a ceiling of some kind in the “bowling alley”, then I’d install blown cellulose above it. You need to make sure you’re leaving air gaps between the roof sheathing and the top of the insulation around the “bowling alley” area.
    请注意,您基本上是在这里建造一个“故事半”的鳕鱼风格房屋之一,因此您将拥有所有相同的绝缘和空气密封问题,这些房屋必须处理这些房屋。
    Bill
Recent Questions and Replies
