GBA徽标水平 Facebook LinkedIn 电子邮件 Pinterest Twitter Instagram YouTube图标 Navigation Search Icon 主搜索图标 视频播放图标 加上图标 减号图标 图标图标 汉堡图标 关闭图标 分类
绝缘类型?我应该有一个发泄的阁楼吗?
用户-6813968|Posted inGreen Building Techniqueson
我正在北卡罗来纳州的气候区建造新的建筑房屋。我几乎完成了计划,并且有一个建筑商。建筑商将与我合作,但没有建造节能房屋的经验。我将建造一个2090平方英尺的单层故事3BR 2 BA 2车库房屋没有地下室,并将在带有12英寸浇注的STEM WALL粉底的平板上建造。屋顶将是一种12-6的臀部风格,带有沥青瓦。框架在外墙上为2x6。我计划用木制炉子建造一个节能的房屋作为初级热量,并在地板上加热和拆分单位AC,外部和内部有多个蒸发器。我还计划安装一个ERV系统,以确保房屋中的新鲜空气。还有一个可以烹饪的丙烷燃气炉。还计划使用铜管道和丙烷热水器。房屋将在井上,车库将设有一个用于安装ERV/热水器/井压力箱的杂物室。 House will have 9″ ceilings except cathedral ceiling in living/family room and an 11″ raised ceiling in the entry way. My primary objectives are keeping the house dry to prevent mold and energy efficiency. My question is primarily about insulation and mold prevention. Here are my questions.
1.我应该在屋顶或天花板上有空气密封吗?
2. Should the attic be vented?
3.我需要在丙烷燃气炉上盖上盖罩的化妆空气。
4.我应该在外墙和阁楼中使用什么类型的绝缘材料。
我已经附上了房屋计划以及与地理隔热板的地板内部热量类型。
Thanks for your advice
  1. GBA编辑
    Martin Holladay||#1
    用户-6813968,
    问:“我应该在屋顶还是天花板上有空气密封吗?”
    答:每个房屋都需要空气障碍。空气屏障(或空气屏障)应与绝缘层相邻。如果您要绝缘平坦的天花板(例如,条件阁楼的地板),则空气屏障通常位于绝缘的内部。(大多数建筑商在此位置使用干墙作为空气屏障。)
    如果你有一个绝缘倾斜的屋顶总成(cathedral ceiling), the air barrier is either located on the interior (again, drywall is common), or the exterior (for example, using taped plywood sheathing), or near the vent channel (using ventilation baffles installed in an airtight manner) -- or, even better, your roof assembly will have two air barriers (one on the inside of the insulation, and one on the outside of the insulation.)
    Q. "Should the attic be vented?"
    A. The answer to that depends on where you put the insulation. If you install the insulation on the attic floor, most building codes require the attic to be vented.
    Q. "Will I need to have makeup air for the range hood over the propane gas stove?"
    A. The answer depends on the cfm rating of your range hood fan. For more information on this issue, see射击罩的化妆空气。
    问:“我应该在外墙和阁楼中使用哪种类型的绝缘材料?”
    答:这是一篇文章的链接,其中包含有关墙的建议:如何设计墙。
    Here is a link to an article with recommendations for attics:How to Insulate an Attic Floor。
    - 马丁·霍拉迪(Martin Holladay)
    达娜·多塞特(Dana Dorsett)||#2
    By "...split unit AC with condenser outside and and multiple evaporators inside" are you talking about a ductless multi-split system?
    如果是的,则所有多裂都是热泵,这将自动为您提供木炉的备份加热。如果尺寸为约2吨的冷却负载(运行和激进的手册J,请勿机翼),则有几个2-2.5吨2-4个区域(4个蒸发器,在AC模式下操作时)选项。在大多数市场中,用不错的多切片加热的效率和成本是浓缩丙烷锅炉的成本的一半,不到三分之一的成本,而不到三分之一的电阻成本是地板下热量的电阻加热。
  3. anon3||#3
    发泄。
登录或创建一个帐户以发布答案。
Community
最近的问题和答复
