社区and Q&A
Water heaters / insulation
Thomas Priddle|发布了GBA Pro Help在
我正在改造一个2层,4间卧室,3个全浴室。这栋房子老了,多次加入,外墙上没有绝缘。炉子和热水加热器是巨人,也是老非常非能源效率的家电。
I’m in central illinois so winters are not to extreme but can be at times. I have a $60,000 budget. I am doing 95% of the work myself to save on labor cost. I am having a contractor I trust to come in and help with supporting a second story structure due to opening up a kitchen into dining and living room.
With the budget I have to wire, drywall, insulate, windows, siding, 3 bathrooms, so I cannot spend thousands of dollars on going green, although I would like to spend a little more now and save money later through energy costs.
Right now my monthly cost for heating in the winter can rise close to $700.00 a month. Which is a lot of money in central ILL. I wanted to go with tankless water heaters but everything I am seeing is leaving me with mixed feelings on it. I also wanted to go with expanding foam insulation but again it seems expensive and I hear the blow in can settle over time.
So, any advice on either issue is appreciated. Thanks.
加入建设科学专家的领先社区
  1. GBA Editor
  2. Expert Member
    Dana Dorsett||#2
    The settling rate of blown cellulose is a function of it's seasonal humidity cycling and it's density. In a central IL location you'd do fine at 3.0-3.2lb "dense pack" density, but that isn't a DIY type operation. If you're doing a full-gut solution you could use damp-sprayed cellulose at 2.5lbs density and it would still do fine due to the internal water-activated adhesives, but open cell foam might be cheaper, and would be more air tight than damp spray, if comparable to dense-pack.
    Air tightness is critical for both moisture and thermal performance, no matter what you stuff in the cavities. Air sealing the and insulating the basement/crawlspace usually has thermal performance benefits far beyond what the simple R-value analysis would imply, since it reduces 24/365 air infiltration dramatically.
    If you're on the gas grid the pay back on a tankless==NEVER. But they make sense for those who have large spa-tubs to fill. For the rest of us you get equal or better performance out of a condensing tank type water heater.
    你的加热燃料是什么是什么是燃料的本地每单位(加仑,Therms,CCF,无论如何)价格?
  3. LoySengH||#3
    Were you able to find the best solution for your problem? In my experience, you can combine bothsolar water heatersand tankless installations as long as the pump is powerful enough to create sufficient flow to turn on the tankless unit.
  4. Drew Baden||#4
    由于你没有绝缘,我很好奇,如果你有旧的单个窗格窗户吗?那些就像在你的建筑物里有巨大的洞。
Recent Questions and Replies
