GBA徽标horizontal Facebook LinkedIn 电子邮件 Pinterest Twitter Instagram YouTube图标 Navigation Search Icon 主搜索图标 视频播放图标 加上图标 减号图标 图标图标 汉堡图标 关闭图标 分类
绿色建筑新闻
Education Center Wins 2013 Net-Zero Prize
Nesea引用了缅因州的320万美元项目,以实现净零能源以及公共影响力和建立创新
Image 1 of 3
A new education center在NESEA 2013年零净能源建筑奖的获胜者Boothbay的沿海缅因州植物园中,包括45 kW的光伏系统和各种能源持续的功能。
图片来源:罗伯特·本森(Robert Benson) - 罗伯特·本森(Robert Benson)摄影
除了节能之外Nesea说,教育中心是一座“设计精美的自然光线建筑,以清脆,温暖和现代的方式与缅因州的乡村形式相呼应。”
2013年零净能源建筑奖的获得者在波士顿的建筑能源13会议上获得了荣誉。[图片来源:Matthew Cavanaugh]
Image Credit: Matthew Cavanaugh
An 8,200-sq. ft. education center at the Coastal Maine Botanical Gardens has won the 2013 Zero Net Energy Building Award from the Northeast Sustainable Energy Association (NESEA).
这Bosarge Family Education Center was designed by Maclay Architects of Waitsfield, Vermont, and Scott Simon Architects of Portland, Maine. The center was built by Bensonwood of Walpole, New Hampshire. Andy Shapiro of Energy Balance was the energy consultant and Thornton Tomasetti of Portland, Maine, was the LEED consultant.
“Not only did this northernmost building achieve net zero energy in a challenging climate with the most heating degree days, it was also pre-assembled primarily off-site,” NESEA said在宣布该奖项时。“该建筑物令人印象深刻的气密水平证明了建筑商,沃尔波尔的本森伍德,新罕布什尔州,设计团队和过程。它还给该行业带来了巨大的希望,该行业主要依赖于定制,现场建造且资源丰富的结构,以达到这样的能源绩效水平。”
In addition to delivering high performance, NESEA said the center also is a “beautifully designed, natural light-filled building that echoed rural Maine forms in a crisp, warm and contemporary way.”
植物园位于缅因州Mid Coast地区的Boothbay。
该中心有一个45 kW的光伏系统
Features of note:
  • Above grade walls insulated to R-40 with dense-pack cellulose in an 11 7/8-in. I-joist cavity.
  • 16英寸R-60的屋顶纤维素绝缘。深i-to-to-to-to。
  • Nanogel-filled and triple-glazed skylights.
  • A Mitsubishi air-source heat pump for heating and cooling.
  • A total of 237 photovoltaic panels, 135 on the roof and another 102 on the ground, with a total rated capacity of 45 kW. Estimated annual output is 47 kWh.
  • 高效率照明。
这零净能源建设奖认识到东北地区的“最佳”净零建筑物。Nesea说:“通过'Best',我们的意思是不仅提供效率,而且还提供理想的舒适性,负担能力,可靠性和优雅。”该奖项带有10,000美元的现金奖励。
5条评论
    ARMANDO COBO||#1
    难以置信的...
    因此,换句话说,一个有R40墙,R60屋顶,三层玻璃窗和高效率照明的教育中心需要45kW的系统,以教育PV Salesman如何向房主进行PV销售?奖励和$ 10K?
    Maybe they need to share it with the people in KS to educate them in Sustainability!!!
  2. GBA编辑
    Martin Holladay||#2
    Response to Armando Cobo
    Armando,
    Maybe I'm being dense, but I'm not sure I get your point. Are you saying that a 45-kW PV system seems to be excessive to meet the needs of an 8,200-square-foot education center?
    ARMANDO COBO||#3
    Big time excessive
    我以为他们的建筑物具有相当不错的建筑物围墙,并且他们的加热冷却负荷确实很低。再加上许多自然和高效的照明,即使对于NE,我发现45KS系统至少是需要的两倍。除非他们安装了几个ECARS充电站或获得很多学分,否则所有人都在博客上几个星期。如果我们可以在SW中进行大约1W/sf的净零,我是否认为NE需要4.5W/sf?不!!!
    NE中的太阳辐射约为SW的66%:http://en.wikipedia.org/wiki/file:us_pv_annual_may2004.jpg
  4. GBA编辑
    Martin Holladay||#4
    Armando,
    First of all, I doubt that you know the types of educational displays or educational equipment included in the building. (I don't.) So it's hard to judge its energy consumption by comparing it to a house.
    Second, Maine gets about half the insolation per square foot that New Mexico or Arizona does.
    这是有关Bosarge家庭教育中心的更多信息:“由Maclay Architects和Energy Balance的Andy Shapiro设计的这个超高效的建筑信封可从代码中降低50%的构建能源使用情况,并导致建模的能量强度的模型强度19
    kbtu/sf-yr。平均而言,LEED白金结构可降低建筑能源的使用率30%。安装了45 kW的PV阵列,以提供运行建筑物所需的能量的100%。”
    ARMANDO COBO||#5
    很公平。
    Beyond Ecar chargers and extra credits, I should have included additional equipment, displays, pools & Jacuzzis, welders, 50 plasma TVs; yet still, NM Solar Radiation averages 6.0 kWh/m2/day and Maine is 4.5 kWh/m2/day or 75% of NM. IMHO, that tells me, a. their building enclosure is not as tight, b. they do have a lot of displays and stuff or c. oversized (leaning to)
登录或创建一个帐户以发布评论。
有关的
Community
Recent Questions and Replies
