GBA徽标horizontal Facebook LinkedIn 电子邮件 Pinterest 推特 Instagram YouTube图标 Navigation Search Icon 主搜索图标 视频播放图标 加上图标 减号图标 图标图标 汉堡图标 关闭图标 分类
博客
地毯是四个字母的单词吗?
Stop, Look, and Read On
理想的构造图也是健康的地毯,也很健康!
如果您正在考虑为您的房屋或项目墙壁到墙壁地毯,请停滞,查看和阅读。在购买下一个房间之前,请花一点时间考虑地毯选择的利弊。
地毯是舒适的代名词 - 它的柔软,吸收声音,并在字面上和形象上使房屋更温暖。不幸的是,这也导致室内空气质量(IAQ)较差 - 充满气体的挥发性有机化合物(VOC),吸收和保留水分,可以导致霉菌,并且是污垢和灰尘螨的巨大污垢。
我们的第一个家有一个可爱的斑点蛾粗毛carpet (came with the old farmhouse!) that I decided to rip out early one Saturday morning. I was stunned by the amount of detritus that had worked its way down through the carpet and pad to the old wood floor. We removed buckets of debris from that house and eventually refinished the beautiful old wood floors. That experience and visual is still with me 25 years later (thank you for indulging my digression!).
If your heart and feet are set on carpet, go with natural fibers, like wool, hemp, silk, linen, and sisal. My favorite is wool: The innate beauty and durability of pure wool provides a natural soil barrier, adds warmth and comfort, is inherently flame resistant—plus, it comes from a renewable resource. Look for natural fiber carpets free of toxic dyes, pesticides, herbicides, and flame retardants. Two of my favorites are地球编织and大自然的地毯,两种100%的羊毛都以坚实的环境实践为补充。
Carpet is two-faced. Check the content literally from front to back, as the carpet backing is equally important as its face. Look for backing made from natural latex, rubber, hemp, cotton, and jute, all of which can come from nontoxic, renewable sources.
如果产品是由天然原材料制成的,并且不含添加的毒素,则可以在生命的尽头负责地生物降解。
通过使用粘贴条代替粘合剂来确保健康的地毯安装,可以装有VOC,并使地毯更难卸下/更换/更换/重复使用/回收。填充会增加柔软度和地毯的寿命,因此,再次寻找天然羊毛和橡胶。有许多由回收产品制成的。
经常使用HEPA真空清洁地毯。在安装天然纤维地毯的头几个月内,它将释放出健康数量的纤维丝 - 这是正常的,三到六个月后将消退,具体取决于日常交通和磨损图案。天然羊毛地毯很少需要洗发;用无毒产品斑点“干”清洁可保护纤维固有的羊毛林的寿命,即天然的污渍屏障。如果您选择洗净地毯,请使用众所周知的资源中的无毒的天然清洁工AFM SafecoatandEarth Friendly Products。
坚持认为,家人和客人走进门那一刻,我仍然和我丈夫一起在那个房屋规则上工作!安的文章“最喜欢的东西:鞋长凳,”还提到鞋子在农药和其他有害和有毒的化学物质中如何追踪,它们坚持并堆积在我们的地板上,尤其是在地毯上。
最后但并非最不重要的一点是,要求可持续地毯认证和标准:
  • 绿色标签和绿色标签Plusare second-party certifications from the Carpet & Rug Institute (CRI) for addressing indoor air quality. Carpet, padding, and adhesives that carry these labels emit minimal VOCs and formaldehyde and are typically free of flame retardants (polybrominated diphenyl, ether).
  • 经历过的产品NSF/ANSI 140-2007 Sustainable Carpet Assessment Standardwere evaluated for their full life cycle—public health, energy efficiency, content, and manufacturing process— and meet recycling goals set forth by Carpet America Recovery Effort (CARE).
地毯行业是第一个为环保产品生产ANSI批准的多动式认证。
我更喜欢我的saltillo瓷砖地板的灵活性,清洁性,耐用性和长寿,在我的主要生活区域和工作区域中带有美丽的区域地毯。但是我必须承认,卧室中的100%自然羊毛地毯是两全其美的理想融合。
6条评论
  1. GBA编辑
    马丁·霍拉迪(Martin Holladay)||#1
    另外两种清洁方法
    对于那些喜欢常规使用HEPA真空吸尘器的传统清洁方法的人来说,这是我清洁地毯的两种方法:
    1.将它们放在晾衣绳上,并用地毯搅拌器或普通的扫帚剧烈殴打它们。只要您认为是必要的,或直到灰尘停止掉落为止,执行这些动作的两到三倍。
    2.在一个寒冷的冬天,将地毯铺在干净的雪上,然后用靴子踩在地毯上。翻转地毯并重复。干雪非常适合清洁地毯。
  2. 格伦·萨默斯||#2
    An Often Over Looked Flooring Issue
    关于地毯的好建议。我也选择瓷砖,但是在大多数情况下,仍然需要用面积地毯“热身”。
    非常惊讶的是,我们看不到更多关于坡度地板上平板的水分问题的文章。在大多数情况下,它留给了地板分包商,以担心水分蒸气弹性。当然,他们想要一个良好的安装,而不必担心保修或回电问题,但他们也希望与定价具有竞争力,并且在大多数情况下,不建议您建议与处理混凝土板相关的额外费用以防水。
    我们在平板下安装蒸气屏障,并寻找具有低孔隙率和良好强度的混凝土,但是我们仍然没有通过防水混凝土板来吸引问题。蒸气屏障受到所有类型的渗透以及机械师意外冲孔的损害,并说“我们对混凝土越过它的混凝土都要付出了什么”。暴露于侧面大气的平板边缘呢?即使有水分屏障,水分也可以进入基质!
    假设我们有一位安装承包商或建筑师,它可以额外使用英里,并在安装底层之前要求ASTM 2170测试!好消息,板内部的湿度不到70%,可以安装好!几个月后,我们看到水分问题,开始挠头,责备游戏开始!
    难道是带有MERV 9过滤的高效,可变的速度HVAC系统正在引起问题吗?你最好相信它。在删除房屋内部的湿度方面做得非常好,我们非常小心以使HVAC缩小我们的HVAC,我们将水分从平板中拉出,使其通过所有混凝土中的凝胶孔/毛细管系统进入内部潮湿的环境较少结构。
    当水分开始通过平板迁移时,我们看到2170测试的70%的R/h读数就在窗外,寻求那种凉爽的低湿度内部。在湿度高,大量的雨水和高地下水桌子上扔出水分。它将破坏债券的凝结和饱和填充物和地毯,我们的室内环境质量通过我们所做的测试而驶出同一窗口!
    是否曾经在医院走过走廊,看到气泡在地板坡度上方3/8英寸上贴上了3/8英寸的气泡?曾经见过维护人员使用剃刀刀将它们切开,只是吸收了在其非常昂贵的无缝橡胶地板系统下积累的水吗?将其切成浸泡的水后,很难对手术室的地板和胶带固定在一起!此外,“看起来不好”。
    是的,面对2,000平方英尺的防水费用约为1,000.00美元。混凝土楼板。以后更换地板会花费多少?当室内环境质量进入时,水分将如何处理。在CSI第03-05-00节中寻找混凝土防水化合物并避免出现问题的情况非常简单。
    经过the way, you can use the same stuff to permanently seal the grout joints on your tile floor, providing the tile guy uses a Portland Cement based grout. Keeps anything from penetrating into a grout and staining it.
    Off my Soap Box for now! Glenn
  3. Annette Stelmack||#3
    地板上的地毯清洁和平板
    嗨,格伦,
    I love your soap box! Excellent information and strategies for slab on grade flooring...thank you!
    嗨,马丁,
    我喜欢夏天,不渴望下雪,但我期待为我的区域地毯尝试您的“干洗”方法。
    谢谢绅士!
  4. 达伦娜||#4
    So I wool carpet would be my
    So I wool carpet would be my best shot... I am actually interested in a carpet that can get cleaned fast with no additional effort, I have my share of bad experiences with carpets, even now with my relatively new carpet I have appointments at the carpet cleaner's once in two months besides the daily regular vacuum cleaning.
  5. Annette Stelmack||#5
    羊毛地毯
    我对我们100%自然,未染色的羊毛地毯有积极的经验。它是16年前安装的,看起来仍然很棒。多年来,许多猫和狗的不幸事故,我们让它们干燥,它们通常是真空的。如果剩下任何污渍或残留物,我使用7世代的地毯和斑点污渍去除剂或小苏打,都可以很好地工作。
    I have to admit that we usually only vacuum 2-3x a month - the carpet is on our stairs and bedrooms which sees no shoe traffic so stays fairly debris free.
    Hope this helps, let me know if you have any other questions. Good luck!
  6. trish持有者||#6
    羊毛地毯
    关于羊毛地毯的所有相同的话,公平吗?我的绿色家中有几个,经过2年的交通繁忙,饮料溢出,皮草球,猫呕吐和相当多的有氧活动,它们看起来全新。(我没有健身房会员资格)。
    有人告诉我,我必须将它们送出专业清洁。我真的不想处理这个问题,我不相信这是特别必要的。很想听听别人怎么说。我们使用了卡拉斯坦(Karastan) - 本地制造的产品 - 我绝对喜欢它们。
登录或创建一个帐户以发布评论。
有关的
Recent Questions and Replies
