图片信用:大卫凯利
Small communities of Passivhaus-certified and net-zero energy houses seem to be popping up more frequently. Two more are in the planning stages this year in New England, one in Boston and the other in Bangor, Maine.
在班戈,一个小城市远离缅因州沿岸的大量资金和昂贵的建筑,房地产公司正在努力占据一批由商业洗衣店占据的六个房屋的计划。项目经理David Kelly说他希望所有人都可以通过乘客认证。
在波士顿,城市官员开始接受开发商的建议,在城市的特派团山区11个空置城市拥有的净零能源房屋。根据一篇文章Boston.com, the houses will be expected to produce more energy than they consume, not just be net-zero consumers.
班戈的Ecohomes
班戈项目是房子兴奋剂的工作nd Kelly Realty Management, which owns and manages both commercial and residential properties in the city of 33,000.
Kelly表示,第一所房子的细节仍在锻炼身体,但他目前倾向于一个结构2×4墙,具有非结构的i-托梁,产生腔体进行绝缘。“似乎真正的成本是可行的,并且可以容易地转移到该地区的绝缘和框架船员,”他说。
There are six potential house lots on the site. Preliminary plans call for houses in the 1,000-to-1,500-sq. ft. range, selling for between $200,000 and $250,000. Kelly expects most to be two-story designs and says it’s unlikely they’ll all look the same.
大票房子沿岸普通,漫长的目的地,用于富有统计数据和退休人员。但是班戈是州北方国家的门户,金钱更紧密,高效,高端房屋不是常态。
“It’s a very different culture, it really is,” Kelly says. “And in addition, it’s a very different financial demographic, so we have to build it super affordable to make it feasible for people.
“第一个是我们有机会获得如何做出如何做的大会并获得模型房屋,”凯莉补充道。“该地区实际上没有任何其他结构,这取决于我们正在努力的标准。因此,能够向人们展示并走过它并走过这一点,我认为,在这个领域的关键。“
Kelly表示,在房地产业务的几年里,他在各种建筑项目中与父母合作。但是,这位27岁的人说他在哲学中有背景,而不是建筑,他现在发现自己设计房子,努力营销和估算,甚至在能源建模中迈出第一次运行。
In addition to building high-performance houses, Kelly says a second important focus will be “permaculture site planning,” which he described as using landscaping and site features creatively.
“当我们设计被动太阳能避难所时,我们已经仔细地思考了它如何与周围环境进行互动,许多级别,”凯莉在后续电子邮件中写道。“生态设计涉及扩大超出壳的考虑因素 - 在整个网站上的景观环境。”
Boston’s E+ Community
Boston is collecting proposals for a mixed-use project of commercial, retail and residential space on 1.3 acres of land in Mission Hill. The project is part of an initiative launched by the city’s mayor in 2011 to encourage “deep green, energy positive, healthy and sustainable communities.”
开发商直到6月中旬提交提案,城市希望在今年年底之前选择获胜者,建设于2014年开始。
There are two sites, which developers can bid on together or separately. In all, the city sees room for as many as 35 residential units.
根据Boston.com,波士顿全球网站,开发人员将需要满足某些先决条件。住房将不得不满足LEED-PLATINUM标准,14,000平方英尺。空间必须保留为社区花园。此外,该市将要求15%的住房价格经济价格。提出的开发人员比将优先考虑到这一点。
该计划中的第一个“能量阳性”项目是8,000平方米。FT。全球罗克斯伯里的四个连栋房屋,每个都是一家三居室单位,拥有39个太阳能电池板和其他节能功能。
0评论
登录或创建帐户以发布评论。
注册 登录
