图像信用:哈博遍的设计
通过让暖空气逃脱高,同时从下面带入凉爽的空气,您可以在没有空调的情况下冷却您的房子。
As most people know, all else being equal, warm air rises. This is good news if you are interested in passive ventilation. Cross-ventilation with windows on opposing walls, catching the prevailing winds, is a good way to bring in fresh air when weather permits.通风的另一种好方法是利用“stack effect.”The cupola pictured has two electrically controlled awning windows, placed to catch the prevailing winds, and two fixed windows to keep the cost down. An open shaft leads to the two-bedroom guest suite below, bringing in natural light. When rain hits sensors mounted on the sills, the windows automatically close. Normally I am not a fan of gadgets, and I believe that one goal of green building should be toreduce electricity usage.雨传感器的小奢侈似乎有价值,即使它并不完全被动。
自然光线杯子带来了取决于窗户的尺寸和轴的宽度和高度。在4英尺正方形的圆顶上图中,在白色涂布的轴上进行了足够的光,以消除下面走廊中的白天照明的需要。点亮或通风更大的空间,考虑将圆顶沿脊延伸到称为“监视器”屋顶的形式(顶部这一页示出了监视器屋顶的示例)。
What about warm air rising in the winter,when you want it down in the living space? Won’t the stack effect pull heated air up into the shaft, where it will leak out the windows? It shouldn’t. In an well-insulated, air-sealed house, temperature stratification is minimal. There should not be more than a few degrees’ difference between the floor and the peak of the roof. Even in a tight house,对流环may be created in a vaulted-ceiling great room, where a lot of air is in contact with a lot of surface area, which is in turn in contact with the cold outdoors. Warm air rises, cools, and then falls to the floor, which is felt as a draft. In a cupola shaft, however, there is comparatively little air and surface area compared to the amount of floor area, so convection loops are not as noticeable.
注意绝缘和空气密封,though. Because they are not common, and some unusual framing is involved, it is difficult to insulate a cupola to the same level as conventional walls and roofs. As with any framing-intensive area, it’s a good idea to wrap either the inside or the outside of the beams that support the cupola with rigid foam to eliminatethermal bridging.
圆屋拉也不是吝啬窗户质量的地方,即使很难看到高度冬季舒适度,以及你的能源账单。
A few more tips:
让圆顶杯足够大。一个经验法则是使圆顶1/10至1/8镶嵌的山脊的长度。这可能似乎太大了,但似乎在地面上的超大似乎在屋顶上看起来很小。虽然不要过度呢:在屋顶的1/6或1/5的尺寸上,圆顶杯看起来就像它不能在它下面的房子支持。
Matching proportions from the house is another way to design a good-looking cupola. If the house has horizontal proportions, use similar proportions on the cupola. A house with a hipped roof will look good with a similar roof on the圆杯子。不要忘记风向标。
4评论
Natural Ventilation
You definately have it right here and we would love to utilize these and other passive ventilation methods you haven't mentioned here. However in the midwest we find that it becomes much more an issue of humitity that causes many of our clients not to utilize them as much. I'd say for the most part many of the homes built today go from using heat to using AC never opening up windows or utilizing the real benefits of a good breeze. We are playing with a passive system that draws air aroung the envelope without passing through interior space. I'll have to get back to you as we move forward on that.
EC&D DAN
这不是热量,这是湿度
Dan, I would be interested in hearing more about your envelope ventilation system. Humidity is a problem here on the coast of Maine too; we have some of the widest swings in relative humidity in the country but the sultry days of summer don't last long. Moving air always feels cooler than stagnant air. I imagine a properly ventilated house there would be comfortable much of the time, if not all the time.
你能告诉我窗口和打开机制细节吗?我想做这篇文章介绍了冥想工作室的事情
Thank you
Don
You're stretching my memory--I built that project in 2006 and wrote the blog post in 2009! Lucky for you I have a good memory for certain things. Those were Kolbe & Kolbe Windows (now called Kolbe Windows), awning-style operation. I just checked their website and don't see the automated hardware listed but it might still be an option. (https://www.kolbewindows.com/windows/ultra-crank-out-awning#Op134&OpT607&OpS2844&OpSI7788)有电动机打开和关闭窗口,在窗口上,窗台是一个小型电子传感器,可以在感测水时告诉电机关闭窗口。我相信其他品牌有类似的硬件,也可能有之后的市场选择。
Sign up Log in
