Questions about insulation and siding
罗索|Posted inEnergy Efficiency and Durabilityon
我有一栋旧房子建于1945年,它的板条和石膏内部装有木头剃须,在现有的2×4螺柱墙中用作绝缘层。我想卸下外部灰泥,更换所有窗户和门,并用新的工程木制壁板覆盖外部。我可以在外部加入1英寸的渗透泡沫绝缘材料,绑住墙壁以在泡沫和壁板之间提供空间空间吗?还是这会长期导致问题?我正在考虑的产品是一种可渗透的泡沫,在防止外部浸润的同时增加了绝缘材料,该产品由Iko出售,称为Ener Air。我住在温尼伯·曼尼托巴省,该气候与大福克斯ND相同。
thanks.
GBA细节库
由气候和房屋部分组织的一千个建筑细节的集合
搜索和下载施工详细信息
罗索,
您住在气候7,这很冷。只要刚性泡沫的最低R值为R-10,就可以添加外部刚性泡沫。这意味着2英寸的XPS或Polyiso或2.5英寸的EPS。
如果您想安装蒸汽渗透的绝缘材料,则可以使用连续的矿物羊毛层。如果使用矿物羊毛,则可以选择想要的任何厚度。当您使用矿物质羊毛时,没有最小的R值。
以下是几篇文章的链接,其中包含有关这些问题的更多信息:
计算刚性泡沫护套的最小厚度
How to Install Rigid Foam Sheathing
用岩石丝网包裹旧房子
我希望我可以跳入这个线程。
马丁,我在墙有2 x6 r-19气候佐恩e 6 with an interior polyethylene barrier. If i put 1-1.5" of roxul comfort board on when residing, I wouldnt have to worry about the dew point causing moisture issues on the plywood sheathing?
Jeremy: With the polyethylene sheeting you already don't have to worry about dew point issues, since you've blocked the diffusion path from the humid interior to the cold sheathing. Adding vapor permeable insulation such as rock wool doesn't make it any worse, it only makes it better.
仅1.5英寸的摇滚羊毛不足以跳过内饰上的聚乙烯(或其他低温蒸气延迟),但是只要它具有一个水分,只要它具有一个水分,只要它具有一个水分,只要它具有一个水分含量干燥路径通往外部。
因此,我阅读了以前的博客,我了解水分等问题,但是我提到的渗透性泡沫板又如何提到了Ener-air。它的perm级额定值为60,而Tyvek的Perm率为57,所以在我看来应该这样做。充分向外部排出水分?这是一种相对较新的产品,与箔纸的东西不同,它不可渗透。我仍然应该将其绑在泡沫上?
Yes, high-perm foam exists, and should work fine, but it's a specialty item.
https://www.iko.com/na/publication/ener-air-brochure-2/wppa_open/
是的,您仍然需要至少在高层泡沫和壁板之间至少有一定数量的通风空间,以便有一条良好的干燥路径通往外部。
I was under the impression there was a minimum r value suggested when adding exterior insulation. Good to know i can add some during my future re-side. I would prefer to add more but my roof overhang at the gable ends is only a couple inches
最小的外部R仅在外部绝缘材料的蒸气渗透量低并且没有内部聚乙烯时才需要。
If you have the interior polyethylene keeping to the minimum is still a good idea with exterior insulation that has low vapor permeance (like most rigid foam), but rock wool doesn't have that problem, but most rigid foam. With low-permeance exterior insulation it creates something of a moisture trap, but as long as the temperature of the sheathing is warm enough, it (usually) stays dry enough.
If there is no interior vapor retarders (defined as < ~1 US perm in Canadian building codes) the minimum exterior R is mandatory even if it's high permeance insulation. This is because the plywood or OSB sheathing itself has too a low vapor permeance, and will accumulate moisture coming from the home's interior if it's too cold, even when there is a drying path toward the exterior.
谢谢Dana,我想在我的情况下,使用Roseau提到的Polyiso Ener-Air产品之类的东西将更有意义。它将为我的有限空间提供更多的R值。
