绿色基础知识
防水障碍
关于防水障碍物远离易受伤害的建筑部件,防水屏障(WRB)是安装在护套(或螺柱)之间的材料,如果没有护套)和壁板。它旨在防止水到达可能被水分损坏的建筑部件。建设者应该假设壁板网关并不真正防水,并且一些水将通过或围绕壁板(至少有一段时间)找到它的方式。没有WRB,墙壁组件的护套和其他部分会更容易受到损坏。WRB可以是几十个商品名称出售的各种材料之一。建筑纸,沥青毛毡和D级建筑纸有两种类型的建筑纸;塑料房屋套房如tyvek和typar;刚性泡沫绝缘;液体涂膜;拉链系统护套; and a unique product called Delta-Dry. Most WRBs are vapor-permeable. Whatever type is used, it’s essential that wall assemblies have the ability to dry out. WRBs are required by code The International Residential Code requires builders to install a layer of number 15 asphalt or paperbacked stucco lath over the wall sheathing or studs. However, builders can still meet this requirement with some “other approved water-resistive barrier.” A number of materials have met the requirements of the International Code Council Evaluation Service (ICC-ES) for use as a substitute, including plastic housewraps, liquid-applied WRBs, Grade D building paper, and certain wall assemblies incorporating rigid foam insulation. WRBs are not actually waterproof Common WRBs, including most housewraps, asphalt felt, and Grade D paper, offer only so much protection against water. Eventually, water will get through. George Tsongas, a former professor of mechanical engineering at Portland State University, says, “In fact, they are not moisture barriers. If you get any significant amount of water…
本文仅适用于GBA总成员
9评论
  1. 阿尔伯特鲁克斯||#1
    在zip上处理切削边缘?
    因为,正如我所理解的,Huber Zip产品是编织WRB到专门的OSB面板层压。在我看来,这是一种“局部治疗”,对于面板的切边,建议采用什么治疗方法?如建筑角落处搭接、门窗反渗透、服务渗透等。标准的做法是用胶带和剪边来密封它吗?
    马丁·霍洛拉||#2
    回应阿尔伯特车
    阿尔伯特,
    根据Huber提供的安装说明,面板边缘未被切除的特殊处理。以下是使用安装说明的网页的链接:
    http://www.zipsystem.com/installation/wall-乐曲.aspx.
  3. 肯列维森||#3
    需要一些更新的信息
    Solitex Mento 1000和Mento Plus WRB可以公平地描述为“防水”。请参阅这里的规格表:http://www.foursevenfive.com/spec/SOLITEX%20MENTO%201000%20Spec.pdf
    带有胶带接缝,它们还可以提供被动房屋级气密性 - 同时也是相当蒸气。查看此处的膜的描述:http://www.foursevenfive.com/index.php?main_page=page&id=15&p=533
    Solitex Mento膜的防水性能也没有通过建造现场污染物或木材壁板单宁来降解。
    SOlTEX Mento薄膜提供了一种负担得起的高性能方法。在美国各地都可以买到http://www.foursevenfive.com。
    我希望您可以更新此WRB发布中提供的信息。如果您有任何其他问题,请告诉我们。
    真挚地,
    肯
  4. 阿尔伯特鲁克斯||#4
    谢谢马丁的链接
    我读了简短的指示。由于这是一个整个墙壁WRB,Huber需要一个1/8“间隙,其中4'边缘相遇,因此WRB系统严重依赖于磁带接头,磁带绑定以停止天气。对于每个面板都有需要持续到建筑物的生命的12英尺的磁带联合。这些关节甚至没有引力研磨的好处(是右词?)。
    它确实让我欣赏一个良好的研磨膜,因为它们可以以一种方式铺设,即使胶带关节失败,适当的研磨会将水留出。
    不是我甚至承认磁带失败:)(只是开玩笑......一切都在某些时候失败了。)
    马丁·霍洛拉||#5
    对Ken Levenson的回应
    肯,
    对规范表的链接并没有真正告诉我Solitex Mento如何在没有Rainscreen差距的情况下在墙上表现。如果膜在圈子壁板和护套之间夹持 - 或者面板壁板和护套 - 没有排水差距,如果我经历墙壁到水管的几个小时,则护套会弄湿吗?
    我不知道答案。但我知道,如果用塑料家庭包装或沥青毛毡进行测试,则护套会弄湿。
  6. 肯列维森||#6
    对马丁·霍洛迪的回应
    嗨马丁,
    我承认没有做到这一特定的测试 - 然而,我自己的轶事测试在高速公路上驾驶4小时,以70万小时的驱动飓风,如暴雨(整个方式),一个大包装在Solitex Mento 1000 Web上包裹汽车的屋顶。抵达华盛顿特区后,我们紧张地删除了WRB,向我们的救济找到了很多,骨干返回WRB和骨干含量内。膜是防水的。(和单宁不会降低它。)
    马丁·霍洛拉||#7
    对Ken Levenson的回应
    肯,
    我认为一些塑料家庭包裹(和30磅沥青毛毡)可能会通过你的“圣诞礼物在汽车的屋顶上”测试。
    这个问题似乎是紧固件和夹层。一旦你装订或将膜固定到墙壁上,并将其夹在壁板和护套之间,大多数膜泄漏。该解决方案应包括在手机和壁板的背面之间的气隙。
    它有点像一个老式的单壁帐篷。帐篷不会泄漏,直到用手指从内部触摸它。然后你的手指弄湿了。
  8. 肯列维森||#8
    对马丁·霍洛迪的回应
    Solitex没有“帐篷效应”。这是一种不同的动物。通过典型的房屋包,当您用手指或其他污染物触摸时,水的表面张力被破坏,通过微眼泪触摸它。Solitex是固体膜 - 蒸汽渗透率处于分子水平。
    同意穿透需要自封/在正压下保持防水 - 如果你有暴露的撕裂,它会泄漏。
    请看看这个小册子:http://www.foursevenfive.com/spec/SOLITEX%20MENTO%20System%20brochure%20475.pdf
    我还会尝试追踪进一步的文档并随访。
  9. 粒状||#9
    代码需要更新。如果我可以将胶合板的接缝(带丙烯酸胶带)/适当地闪光穿透以控制空气并使用Rainscreen,我仍然有一个没有2层Tyvek或15#建筑纸的建筑物。更好的装配而不是像Tyvek或现代15#建筑纸一样的毫无价值的垃圾比我们视线所处。只需跳过毫无价值的Tyvek,将钱花在空中密封,并使用Rainscreen - 可能以几乎同样的成本提供房屋,但大大更好的性能/长寿。
登录或成为一名成员发表评论。
有关的
  • 绿色基础知识
    空白障碍
    空中障碍是建筑信封的重要组成部分
  • 绿色基础知识
    石头和合成石
    一种需要排水垫和蒸气不透水护套的传统外观
  • 绿色基础知识
    选择选择
    壁板是第一次对更新元素的辩护,更新了2013年3月4日
  • 绿色基础知识
    灰水
    通过用灰色水灌溉减少水的使用
