天花板和EPS之间的蒸汽屏障?
约翰·H·斯特曼|张贴绿色建筑技术在…上
计划建造一个木框架。在侧墙上啜饮。1×4或1×6 T&G垂直敷设在天花板檩条顶部。2×6或2×8站在屋顶周围的边缘,像一个盒子。ESP与周边2x材料厚度相同,接缝处有1/4〃的间隙,用于泡沫。接缝处发泡,接缝顶部用胶带固定。2×4平放,从屋檐到屋脊垂直敷设,24〃中心通过泡沫拧紧。OSB或胶合板覆盖在2×4的顶部,然后是玻璃纤维瓦。通风soffet和脊形通风口。
我的问题是:ESP和T&G天花板之间的蒸汽控制需要什么?你对蒸汽进入T&G接头并沿着它到达山脊有什么想法?有什么问题吗?或者我有没有想过?
厕所,
您的EPS下无需设置蒸汽屏障。如果你打算在天花板上安装5.5英寸或7.25英寸的EPS,你的EPS已经是一个很强的蒸汽缓速器了——而且你在任何情况下都不需要蒸汽缓速器。
您的EPS下需要的是空袭。舌头和沟槽板不是空气屏障。如果exfiltrating空气在您的EPS接缝之间,屋顶护套可以腐烂。这种类型的失败发生在阿拉斯加朱诺的数十个啜饮屋顶的家中。
你的计划是用喷雾泡沫和胶带密封EPS的接缝,这是一个很好的计划,但可能还不够。硬质泡沫会随着时间的推移而收缩,密封尝试可能会失败。所以你需要一个防弹空气屏障下的EPS。
在您的EPS下,您可以将合成的屋顶衬垫安装有胶带接缝,或带有胶带接缝的房屋包,或带有胶带接缝的欧洲膜之一。然而,由于屋顶工人将在这面行走,如果我是你,我将在舌头和沟槽板和eps之间安装OSB或胶合板。别忘了擦拭OSB或胶合板的接缝。
如果要安装一层较厚的EPS,则应至少安装两层交错接缝的泡沫,以限制接缝处的空气泄漏和热桥接。
马丁,谢谢你的回复。我读到了朱诺。糟糕的工艺给出了一个坏名字。我位于宾夕法尼亚州兰开斯特。温和的气候温和。我有一个关于啜饮的Joe Lstiburek书的副本。我不能直接在我的脑海里,蒸汽障碍和空袭之间的差异。我一直在在线看待这么多产品,它正在推动我坚果!一些产品被描述为空气和蒸汽屏障。我正在考虑使用瓦盖下的Grace Tri-Flex。它具有0.04的渗透性。 What excatly is this telling me? Would a higher or lower number be better? Unless you roll out poly plastic above the ceiling I cant imagine there will not be some air leaks down the road. That is why I have the mindset that you need a ventilated roof. I am planning on an airspace above the esp with ventilated soffit and ridge. My real concern is even with a proper air barrier on top of the t&g the air will get in the t&g, travel uphill to the end of the board at the ridge. The ends meet at the peak right above the ridge beam. If the esp at the peak is foamed and taped like it should be then what happens with this air that collects in this small void? I know of a local fellow who had a timberframe addition added to his house. It had the planked ceiling. Water started dripping from the ceiling. They ended up removing the roof and redoing it. I do not know all the details but it is on my list to find out. Thank you for your help. You have a great site with a wealth of information. I grew up in the era of leaky houses but I do understand the concerns of building a tight house.
厕所,
你写道,“我知道一个当地人在他的房子里加了一个木结构。它有一个木板天花板。水开始从天花板上滴落。他们最后把屋顶拆了,重新装修。”
您已经描述了通过舌头和沟槽天花板泄漏的经典症状(和结果)。这就是你想要避免的。
虽然你似乎相信聚乙烯是最好的空气屏障,但事实并非如此。带有胶带接缝的胶合板或带有拉链带的拉链护套可能比聚乙烯更气密、更耐用,因为聚乙烯易碎且容易损坏。
0.04 perm的磁导率相当低。这将被视为蒸汽屏障。要了解磁导比例,请参阅本文中的示例:我需要蒸汽减速器吗?
你问,“数字越高或越低越好?”答案是,“这要看情况而定。”有时你需要一层薄膜,让建筑组件干燥;那将是一个蒸汽渗透膜。有时你需要一层薄膜来防止湿气进入建筑组件;那将是一个蒸汽屏障。
有关空气屏障和蒸汽缓速器之间区别的更多信息,请参阅以下文章:
有关空气屏障的问答
蒸汽缓凝剂和蒸汽屏障
忘记蒸汽扩散-停止空气泄漏!
空气屏障或蒸气屏障?- 建设科学播客
一个评论请求,就像一个评论:我目前正在一个木框架上建造一个(有点)类似的屋顶。我对空气密封也有类似的担忧。在我的T&G板上,在我的刚性绝缘层下,我使用了冰和水屏蔽而不是6密耳聚乙烯。。我跑了很长时间,会把它搭在墙板上。。好啊
迈克尔,从墙壁和天花板中获得绝缘材料。)
是的,这种方法会奏效。这是用于持久性施工的传统方法。(有关持久化的详细信息,请参阅
但是,要注意将剥膜和粘膜在墙上延伸的距离。你真的不想在你的外墙上有一个蒸汽屏障。如果你在墙的顶部覆盖6英寸,不会造成伤害。但是不要把果皮和果皮粘得太远。
迈克尔
只是问问你是如何做你的屋顶系统。你在t&g两端连接的山脊上做了什么?也许我错了,但我认为空气携带水分,所以如果空气沿着t&g向上移动到山脊,它将被捕获。也许在这种情况下,湿气会向内部干燥。就像我说的,有时候我想得太多了,这甚至都不是一个问题。
厕所,
如果内部水蒸气在空气屏障内侧的内侧“被困”,则可以。毕竟,您不希望水蒸气穿过屋顶装配。空中障碍的整体目的是你的热障碍是“陷阱”你的温暖,潮湿的空气,并保持空气完全与寒冷的干燥空气分开。
这里有一个木框工人,他身后有几十年的屋顶,他用胶带将两层箔面泡沫和上面的通风口粘在一起。
我从来不会在没有通风的情况下建造这种屋顶。喷射泡沫是我唯一认可的无排气孔屋顶。
T&G天花板的作用就像它们甚至没有安装一样,以确定通过它们的空气量。我曾站在这样一个装置上面的阁楼上,感觉到一股温暖的微风从那种大教堂天花板装置中吹来。
同样,我也亲眼目睹了从一个没有排气的堆积物上滴水的情况。在一个昂贵的房子里住两次,再加上演示,这一切都很昂贵。糟糕的情况。
AJ,
好建议。舌头和沟槽天花板对许多屋顶的故障负责,因此皮带和吊带方法是有道理的。
厕所,
把事情想清楚没什么错。我在山脊的t&G没有做什么特别的事,只是在顶部有更多的冰和水。也就是说,我不太担心R值,而是担心空气密封。因此,我在教堂天花板上用冰和水覆盖T&G,一直覆盖到山脊。这是一座小而简单的建筑。我已经把我的墙板沿着木框架的外侧向下延伸,在我的窗台上放了一块横档板,在上面放置墙板,用垫圈和低膨胀泡沫将窗台、木框架、T&G和天花板密封起来。把冰和水轻轻地放在墙板上。希望这一切都能得到锻炼,我最终会有一个舒适的小营地。
迈克尔
这就是我如何做我的窗口区域,除了那里的白蚁盾牌,你是否在屋顶上使用啜饮或使用不同的系统?现在我想不要因为额外的两层OSB而啜饮,我觉得我不需要。我是一个通风屋顶的坚定信徒,这就是为什么我在顶部的2/4平板上规划,带有护套和带状疱疹或金属。它是我在Tedd Benson的木材框架书中看到的系统之一。
