GBA Logo horizontal Facebook LinkedIn 电子邮件 Pinterest Twitter Instagram YouTube Icon Navigation Search Icon Main Search Icon 视频播放图标 加上图标 减号图标 Picture icon Hamburger Icon Close Icon Sorted
Building Science
您需要了解的有关吊扇的重要内容
Here are a few basic principles that many people don’t understand
Image 1 of 3
This ceiling fan with short bladesmay be cute, but it's not your best choice if you want a fan that moves air.
Image Credit: Alexander Bell
操作过程中吊扇的红外图像。请注意,电动机比房间温暖。
一个吊扇效率标签,显示每瓦的电力106 CFM的效率标签
Image Credit: Energy Vanguard
Here we are in the middle of air conditioning season. So why don’t we chop down some myths and misconceptions about ceiling fans?
What got me on to this topic was a video of a fan with blades that hide on top of the fan when the fan is turned off. Sounds clever, but it’s a ridiculous idea.
Anyway, here are seven things about ceiling fans that a lot of people seem not to know.
1. Ceiling fans heat the room
Yes, a ceiling fan is a cooling device. (See point number 2 below.) But its effect on the room it’s in is to add heat. Why? Because electric motors are devices that turn electrical energy into mechanical energy, most of which ends up as heat. The infrared photo reproduced as Image #2 (below) shows a ceiling fan motor that’s hotter than the room it’s in. From thesecond law of thermodynamics, we know where that heat is going — into the cooler room.
The net result of running a ceiling fan is that you’re adding heat to the room.
2. Ceiling fans cool people
Ceiling fans are useful for cooling only when they move air over skin. They cool our bodies two ways: by aiding evaporative cooling and by aiding convective cooling. If the air movement created by a ceiling fan isn’t hitting anyone’s skin, it’s just making the space warmer with no cooling benefit.
3. A fan’s efficacy tells you how well it moves air
这些天在美国出售的每个新吊扇都是标记有功效。(Efficacy is an efficiency rating wherethe output and input quantities have different units。一个好的风扇会为您每瓦超过100 cfm提供。贫穷的人可能低至每瓦30 cfm。
下次您寻找吊扇时,请检查标签。
4. Bigger is better with ceiling fans
While you’re checking those labels, you may notice a correlation. Thefans with the longest blades have the highest efficaciesand those with the shortest blades have the lowest. That’s why the company Big Ass Fans makes big ass fans.
And it’s why you’ll want to avoid the little short-blade fans, no matter how cute, if you’re interested in air flow. If you just want cute, though, go ahead.
5. Lower speeds are more efficient
查看风扇功效标签时,您会注意到的另一件事是,当您在媒体上运行风扇比在高位上和低点相比,在介质上运行风扇时,您将获得更多的CFM。这里唯一合乎逻辑的结论是让您可以适合房间的最大风扇,留下适当的间隙,并以最低的速度运行,使您保持舒适。
这就是为什么大屁股粉丝公司最初被称为HVLS粉丝公司的原因。HVLS代表大量,低速。
6.如果您有空调,吊扇可能不会为您节省任何钱
Martin Holladay covered this inhis ceiling fan article from 2010, but it’s worth reviewing. If you don’t have air conditioning at all, having some kind of fans can preserve your sanity. You get to keep cool for a relatively low cost.
但是,一旦拥有空调的房屋,动态就会发生变化。那个在皮肤上移动的空气仍然感觉不错,空调产生的低温,低湿气也是如此。假设是,如果人们感觉到吊扇的微风,但数据不支持它,他们将提高交流恒温器设置。
In 1996, the Florida Solar Energy Center (FSEC) did a study of homes with ceiling fans. They found that even though the fans ran more than half the day in the test homes, they saw no difference in thermostat setpoints in homes with ceiling fans compared to homes without.
简而言之,要为吊扇节省您的能源费用,您必须将恒温器设置为更高的温度。我在我家中这样做,但FSEC发现大多数人没有。
7.吊扇会使您斩首
我什至不知道这个神话直到我看到下面的神话巴斯特视频。显然,有些人担心会被吊扇砍掉。正如您在下面的视频中所看到的那样,它肯定会发生……但是,只有当您用更强大的电机(例如割草机电机)替换电机并用剃须刀变种的刀片更换刀片。
So relax! You won’t get your head chopped off by a (normal) ceiling fan. But you can certainly use more energy and make your home warmer by using one.
Oh, and that fan with the nesting blades is a ridiculous idea because it has two problems: The blades have to be short to be able to nest together on top of the motor, and the blades are designed for nesting, not moving air. If you don’t like the looks of a ceiling fan, that’s fine. But why even have something like this at all if it’s not going to move much air?
Allison Bailesof Decatur, Georgia, is a speaker, writer, building science consultant, and the author of theEnergy Vanguard Blog。You can follow him on Twitter at@EnergyVanguard。
9 Comments
  1. 先锋制造商||#1
    Ceiling fan in a large vault
    我们定期构建房屋大金库the great room, dining room, kitchen areas, and we are 100% using mini-split systems. One concerns we've had is the area in the vault getting stale, so we've installed ceiling fans to move the air around. Any thoughts on this? In other words, it isn't about the air touching the skin for evaporative/conductive effect, just air sterility (if that's a word that can be applied here).
  2. user-2310254||#2
    @PioneerBuilders
    您如何通风新房屋?一个好的策略应解决对陈旧空气的任何担忧。
  3. this_page_left_blank||#3
    air sterlility
    不,这绝对不是在这里应用的单词。不育与缺乏活生物有关。空气不育并不是真正的目标,但是即使是,您也不会通过移动空气来实现它。我认为,由于高拱形天花板而引起的陈旧空气的关注是没有根据的。为了使其相对混合所需的空气移动量很小,因此对流电流可能就足够了。即使只是在房间里走来走去也会产生重大影响。
  4. this_page_left_blank||#4
    fan with nesting blades
    有什么例子是带有嵌套刀片的风扇?戴森的粉丝?我尝试搜索该术语,除了筑巢在风扇叶片上的鸟之外,什么也没有提出。
  5. Expert Member
    达娜·多塞特(Dana Dorsett)||#5
    Is stale air even a problem for a vaulted ceiling?
    The relative humidity (RH) of the hot air in the vaulted ceiling is lower than the cooler stratified air near the floor. Mixing it up increases the cooling load by raising the temperature near the floor where the humans are.
    What problems are being avoided by circulating/purging that warm stagnating air near the ceiling?
  6. GBA编辑
    Allison A. Bailes III, PhD||#6
    嵌套刀片迷
    Trevor, here's a video of the fan I mentioned:
    https://youtu.be/T0tGn8MjJn0
  7. STCook||#7
    Lets give a shout out to the newer DC motor ceiling fans that are available. The Emerson ECO line, as one example, is as high as high as 355 CFM/Watt which is quite high for a ceiling fan.
    可以替代标准K55堆栈(我的旧最喜欢)或188个煎饼电动机的替代方案。由于所需的电子设备,直流电动机更加昂贵,但是无声的运行和效率是其中的一些好处。
  8. 删除||#8
    “[Deleted]”
  9. GBA编辑
    Martin Holladay||#9
    用户6895662,
    实际上,所有电流都会通过设备降低加热而绘制的所有电流 - 如果设备在室内,则设备正在加热您的房屋。如果是50瓦的风扇,则每当打开时,它会在房间中加入50瓦的热量,而不是10瓦的热量。
登录或创建一个帐户以发布评论。
有关的
Community
Recent Questions and Replies
